Author Topic: Setup Help  (Read 1754 times)
eraser
Setup Help
« on: April 21, 2005, 08:56:20 AM »
I am just starting to build my solar and wind setup and need some help, this is a first for me and I have drawn up a wiring diagram of what I want to build.
  1.     Does the wiring look to be correct?
  2.     I think the wind volt meter in this set up would read the battery voltage and not that coming from the wind gen , Should I put a diode between the battery and the wind gen volt meter so that it reads only the volts from the wind generator?
  3.     The load regulator on the battery should it be wired through the shunt for the emeter
The Solar regulator is a plasmatronics 24 volt  it has three wires 1 for solar - input , 1 for - Battery and the last is for +solar and Battery combined
Solar Panel is a 24 volt 165watt panel
Wind gen is 800watt made by Mikes windmill shop
Any help would be greatly appreciated.
Diagram is here http://www.geocities.com/eraser1.geo/setup.jpg
« Last Edit: April 21, 2005, 08:56:20 AM by (unknown) »
