Author Topic: how can i tell if my panel has a diode  (Read 1216 times)
adamant
« on: December 01, 2004, 04:10:11 AM »
how can i tell if my used panel has a diode installed in it?
also, i have it tied into a morningstar controler. does that controler have a diode in it?
thanks,
ant
« Last Edit: December 01, 2004, 04:10:11 AM by (unknown) »
drdongle
Re: how can i tell if my panel has a diode
« Reply #1 on: December 01, 2004, 05:38:37 AM »
The diode is usualy in the small junction box on the back of the panel, it will be connected to one of the output terminals.
Carpe Vigor
Dr.D
« Last Edit: December 01, 2004, 05:38:37 AM by drdongle »
Opera House
« Reply #2 on: December 01, 2004, 06:25:05 AM »
That diode will only have a single conection to one of the output lines if it is a blocking diode.  For example, my Photowatt panles have two diodes in the junction box.  These are not blocking diodes.  They are connected across sections of the panel that are in series.   In the case some leaves prevent that section from genenerating, current is allowed to bypass that section.
« Last Edit: December 01, 2004, 06:25:05 AM by Opera House »
« Reply #3 on: December 01, 2004, 11:00:21 AM »
Don't use a blocking diode with a Morningstar controller.
It takes care of everything.
« Last Edit: December 01, 2004, 11:00:21 AM by ghurd »
adamant
« Reply #4 on: December 03, 2004, 03:40:20 AM »
thanks for the info...
ant
« Last Edit: December 03, 2004, 03:40:20 AM by adamant »
