Author Topic: OFF GRID GROUNDING QUESTION  (Read 972 times)
LEMICOUCOULIER
« on: December 19, 2004, 06:59:46 PM »
HELLO!
WE ARE OFF GRID AND ALMOST FINISHED INSTALLING A SOLAR-GENERATOR ELECTRICAL SYSTEM
I AM NOT SHURE ABOUT HOW THE SYSTEM SHOULD BE GROUNDED
SOME TELL ME THAT WE SHOULD HAVE A FLOATING GROUND SYSTEM NOT CONNECTED TO EARTH AT ANY POINT TO PREVENT DIRECT LIGHTNING AND ITS RETURN FIRE FROM THE GROUND
WHERE WE LIVE THERE IS A LOT OF LIGHTNING IN THE SUMMER,EVEN IN THE WINTER SOMETIMES
SOME TELL ME TO GROUND MY SYSTEM LIKE USUAL GRID TIE SYSTEMS TO BE CODE COMPLIANT
ie.INSURRANCES REQUIREMENTS
I DID NOT FIND INFO ON FLOATING GROUND SYSTEMS,DOES ANYBODY HAS A OFF GRID SYSTEM WITH FLOATING GROUND?
« Last Edit: December 19, 2004, 06:59:46 PM by (unknown) »
jacquesm
Re: OFF GRID GROUNDING QUESTION
« Reply #1 on: December 20, 2004, 06:37:34 AM »
The way to ground your system is to ground the structures separately, and put your electrical ground on the bonding point in your disconnect box (that's also where you should bond battery '-' to ground).
We have lots of lightning here too, so grounding is a real issue. While in theory it's true that floating your system reduces the risk of a strike a little bit if it Does hit you have a 100% certainty of trouble.
The way to go about lightning protection is to provide as good a path to ground as early as possible and to avoid inducing voltages in wiring. Bury your wires at least 4' down, and make sure your ground rods really do make a good ground. If that's not the case you will have to pick a 'wetter' spot.
See my other posting on fieldlines regarding inverter connection here, it has all the relevant details in it, except for grounding the structures (panel support posts, windmill towers).
« Last Edit: December 20, 2004, 06:37:34 AM by jacquesm »
