Author Topic: thsnks  (Read 981 times)
MD
thsnks
« on: November 22, 2005, 11:55:30 PM »
thanks guys for the info on the solar panel backdraw at night, going out to get some diodes, thanks again,
mike
« Last Edit: November 22, 2005, 11:55:30 PM by (unknown) »
JW
  • Development Manager
    • Flashsteam.com
Re: thsnks
« Reply #1 on: November 23, 2005, 10:44:04 AM »
I never read the inital info that you got MD,
 but it seems to me that if one is in a temperate climate such as the equator(sp?) you wouldnt need reverse=blocking diodes. Since at optimum operating tempuratures the soler panels would not-in fact try to heat themselves, at night. If the mean-temperatre was optimized then the solar panels would infact transfer power on a positive-bias to the battery bank. I beilieve this is a concern in the solar-car races Down Under(astraillia(sp?)....
 They must cover the the silicon solar cells at night, since in warm enough climate's, the panels can charge the batterys at night, with star-light, even with diodes?. but i believe in outer-space you(or most of the group) are correct. So basically at night in cold temperate climates one does need blocking diodes. The question becomes- is it actually usefull to cover the solar array with a tarp, unless you consider thermodynamics.
Just a thought
JW
« Last Edit: November 23, 2005, 10:44:04 AM by JW »
