Author Topic: $9.99 Canadian Tire solar panels  (Read 1996 times)
Fiddlehead44
« on: April 07, 2006, 04:57:58 PM »
Yesterday, I purchased 10 of those cheap solar
panels. They are for trickle charging a 12V
battery. 1.8W 125 mA Max. About 14"x4". I want
to join them together and make a larger solar
panel. I guess this would be 18 W and 1.25 amps.
Or thereabouts. They have a built in  blocking
diode. They have about 10' of wire and a cigerette
lighter adapter or aligator clips available. I can
identify the positive and negative cable easily.
Should I join all the pos.+'s together as well as
the negatives-?. Also the are designed for inside
of car useage, but I want to use them outside. I
was planning to mount them on a piece of plywood
and cover them with a piece of plexiglass. Would
they get too hot this way? I also could discard
the present frames and just mount the solar cells
directly to the plywood or I could use silicone
and seal them around the frames and not cover them
with plexiglas. Any advise please.
                Fiddlehead44
« Last Edit: April 07, 2006, 04:57:58 PM by (unknown) »
WXYZCIENCE
Re: $9.99 Canadian Tire solar panels
« Reply #1 on: April 07, 2006, 11:14:26 AM »
That is cool, I was going to do the same thing! Went to C.Tire and they were sold out! So you are the one who scooped me! I got a rain check for 10 although. Also if they are the ones I think, they have a small circuit built into them. But don't quote me on that. I will have to actually open one up to see. I will be interested in your outcome. I like to see others familiarize themselves with a method. It only helps others.Thanks, Joe
« Last Edit: April 07, 2006, 11:14:26 AM by WXYZCIENCE »
asheets
« Reply #2 on: April 07, 2006, 12:40:41 PM »
Are they any different from these:
http://cgi.ebay.com/ebaymotors/VW-Solar-Panel-Battery-Charger-RV-boat-SUV-Vanagon-NR_W0QQcmdZViewIte
mQQcategoryZ63687QQitemZ8051610364QQrdZ1
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=44768
____________ Alan Sheets -- asheets@frii.com
« Last Edit: April 07, 2006, 12:40:41 PM by asheets »
« Reply #3 on: April 07, 2006, 02:09:47 PM »
Glad to see you took advantage of the good deal..
yes to hook them in parallel is what you would want to do..
connect all positives together and all negatives together..this will give you the same voltage and ten times the current of one..
« Last Edit: April 07, 2006, 02:09:47 PM by willib »
« Reply #4 on: April 07, 2006, 02:13:18 PM »
As for the heat, in my opinion , the cooler you can keep them , the better off you will be..
« Last Edit: April 07, 2006, 02:13:18 PM by willib »
ElSenator
« Reply #5 on: April 08, 2006, 01:07:01 AM »
I have almost finished a similar project using a dozen of the VW solar panels, an old storm window, 2 pieces of hammered and drilled copper pipe (buss bar?). On the test run, it pulled about 25-28 watts into an almost charged battery. Now I'm working on a frame, and mounting. Pictures in a couple of weeks!
« Last Edit: April 08, 2006, 01:07:01 AM by ElSenator »
« Reply #6 on: April 08, 2006, 05:25:47 PM »
The VW PV I remember testing extensively, put out 3.8W cycling into a full battery.
The controllers are the On/Off type, and the set points seem to vary slightly.
Good sun and a low battery might make 45W.  I'll wait for photos!
Not all VW PVs have the built in controller.
« Last Edit: April 08, 2006, 05:25:47 PM by ghurd »
Spelljammer
« Reply #7 on: April 10, 2006, 03:56:45 PM »
I have used these solar panels before.  I put three together to charge 36 volt battery bank for my recumbent bike.  They aren't weather proof so I mounted on a piece of plywood and stretched some clear 3mm poly over them and stapled it on the back side.  These 3 and the one in my truck all had a problem with the black plastic trim and the heat.  On a hot summer day they will start to seperate and warp.  Works fine though.  If you put a big washer on the screws when you screw them down to the wood then that works fine.  You will still want to weather proof them with plastic or glass to keep the rain off them.  Glass is better than thin plastic becuase the plastic will crack within a year. Also, they have little blinking diodes that may fail too, but the panel itself seems to keep on goin.
« Last Edit: April 10, 2006, 03:56:45 PM by Spelljammer »
