Author Topic: 10w panel which finished 2w  (Read 1103 times)
guruji
« on: July 14, 2006, 02:46:33 PM »
Sir I have installed a solar panel which it was supposed to give me 10w but finished with 2w :(.The thing is with a car voltmeter installed in the system from 21v it went down to 11.4v.Is it maybe this voltmeter is not working ok?
Thanks.
« Last Edit: July 14, 2006, 02:46:33 PM by (unknown) »
Gary D
Re: 10w panel which finished 2w
« Reply #1 on: July 14, 2006, 09:17:57 AM »
If your battery is at 11.4 volts(very low), that is what your volt meter should read. It will take hours(days probably) to bring the battery voltage up charging with a small panel. If your panel is not aimed directly at the sun, your watts will suffer, or if there is a hase, or clouds.... Just a thought. Gary D.
« Last Edit: July 14, 2006, 09:17:57 AM by Gary D »
jimjjnn
« Reply #2 on: July 14, 2006, 09:56:45 AM »
Looks like it is working as it should. You need more panels
« Last Edit: July 14, 2006, 09:56:45 AM by jimjjnn »
Opera House
« Reply #3 on: July 14, 2006, 11:04:21 AM »
A few more details would be appropriate.  Is this a coil type voltmeter and just how do you know it is producing 2W?
« Last Edit: July 14, 2006, 11:04:21 AM by Opera House »
