Author Topic: Reply to Have Spare Land, want to Feed Grid [CLOSED]  (Read 1281 times)
GeorgeB71
« on: August 21, 2008, 05:45:41 PM »
I'd look at concentrated solar power before photovoltaics.  You can potentially get much more power from them than from a PV array for less money.  In a nutshell, build a parabolic solar through collector, run a tube through its focus to heat oil, which in turn runs through a heat exchanger to heat water & make steam, which runs a turbine or steam engine, which turns an alternator.  In reality, it's a tad more difficult than it sounds though.  Look up "Kramer Junction SEGS plants" in Calfornia.  I've been thinking of doing exactly this on sunny desert land in northern Cal.  The problem is that the power company won't pay you much; only about a nickel per kilowatt-hour at best.  You'd need a pretty big farm to make any real money.
You can also buy used windmills from the wind farms in Cal.  150kw machines are available for $17k, which is actially pretty resonable.  That particular machine makes about $1000 per month at it's site.  They're removing them to make way for larger machines.  I thought about buying land in Wyoming, where it's cheap & windy, setting them up, & running them.  Even though Wyoming would pay far less for the power than Cal., you could still get about $400 per month per machine.  Of course you'd need a tractor trailer & a crane to transport & set them up, so the initial investment would still be substantial; say maybe $300k to set up 10 machines or so.  Hope that helped.
- George
It makes tons more sense to respond to that Story rather than spread the discussion over multiple story posts. [CLOSED] to encourage that.
« Last Edit: August 21, 2008, 05:45:41 PM by (unknown) »
