Author Topic: Hot tub heating  (Read 996 times)
huntedheads
Hot tub heating
« on: April 08, 2009, 09:14:23 PM »
I know someone is heating there hot tub with thermal panels in the summer. I run a closed loop antifreeze system (Ohio) and I want to add it in-line some way. Maybe just a ball valve open in summer and closed in winter so I still heat my house water too. But how to control the temp. A flat plate exchanger will work but then how to control temp? Differential tied to some kind of electric valve? How are you doing it? Show me some pictures.
« Last Edit: April 08, 2009, 09:14:23 PM by (unknown) »
jonas302
Re: Hot tub heating
« Reply #1 on: April 10, 2009, 09:35:27 PM »
you could do it manually of course(:
One way would be you would have a taco pump running on the hot tub side of the plate exchanger hooked to a relay and a thermostat made for the water or does your hot tub already have a pump? then you would use a zone valve to bypass the exchanger when the thermostat was satisfied
You would find zone valves in the heating section they are used with radiators in the house
« Last Edit: April 10, 2009, 09:35:27 PM by jonas302 »
