Author Topic: Charging Batteries  (Read 1589 times)
guruji
Charging Batteries
« on: June 09, 2005, 07:52:27 PM »
Dear Sir when charging a bank of batteries it's better to charge one by one then charging all at once in parallel ?
« Last Edit: June 09, 2005, 07:52:27 PM by (unknown) »
Re: Charging Batteries
« Reply #1 on: June 09, 2005, 02:02:04 PM »
I believe they should be charged separately if they are used separately.
Charging in parallel is not as efficient if the batteries are at different voltages in the slightest.
« Last Edit: June 09, 2005, 02:02:04 PM by ghurd »
whatsnext
« Reply #2 on: June 09, 2005, 03:30:08 PM »
But if they are used as a bank I would charge them as a bank. Charging as a bank increases the 'C' rate which means the batteries are being charged more slowly. This means less outgassing which is a good thing for battery life. You still need to equalize once in a while though which may require seperate charging unless you have a large charger.
John......
« Last Edit: June 09, 2005, 03:30:08 PM by whatsnext »
