Author Topic: Different voltages on similar batteries  (Read 4445 times)
zmoz
« on: July 09, 2005, 10:23:43 PM »
I have 3 Hawker AGM batteries that are new, but a few years old. I put them together on a float charge for about a week, and then let them rest for about a week. Hawker says a full charge is 12.84v. Two of the batteries now read 12.86v, while one reads 12.96v. I don't think that's much of a problem; however, I'm wondering what it might tell me about the condition of the batteries. What would cause the difference in voltage? Are some more sulphated than the others or something?
« Last Edit: July 09, 2005, 10:23:43 PM by (unknown) »
Re: Different voltages on similar batteries
« Reply #1 on: July 09, 2005, 07:15:15 PM »
   5 yrs old? IMHO I think you ought to start using them...just light up some tail light bulbs or something
take them down about to maybe 95% full charge
especially the one that is reading low...could
be just one cell is weaker than the others and you
need to cycle it a couple of times then see if that gives you a higher reading.
   You mentioned that you float charge them a
week then give them a rest for a week?
   I must have missed the part where they were
working?LOL
                    ( :>) Norm
« Last Edit: July 09, 2005, 07:15:15 PM by Norm »
zmoz
« Reply #2 on: July 09, 2005, 08:19:28 PM »
Who said anything about 5 years old? They're only about 2-3 years old, and designed to last a LONG time even under abusive conditions. Hawker claims 400 cycles at 100% discharge. I have cycled them to about 50% a couple of times...though I don't have any particular use for them at the moment.
« Last Edit: July 09, 2005, 08:19:28 PM by zmoz »
« Reply #3 on: July 10, 2005, 06:51:45 AM »
  Sorry about the gross misunderstanding...
you didn't say a couple of years you said a few
years (however enough with the semantics).
  It does sound pretty good that they could be
that close to having the same reading now if 2
batteries have exactly the same reading it could
hardly be possible that battery A had all its
cells would have different readings and average
out to tha same average as battery B...so maybe
we could conclude that maybe all the cells in battery C
would read the same except ONE!....
which would drag the total reading down....??
for that battery.
   I don't know that much about batteries ...
thanks for the information about Hawkers,
sounds like the kind of battery I might want to
use in an electric mower someday.
                ( :>) Norm.
« Last Edit: July 10, 2005, 06:51:45 AM by Norm »
Experimental
« Reply #4 on: July 10, 2005, 10:44:43 AM »
     Good morning,
    You are slightly over Hawkers fully charged voltage -- and you are talking about .1 volts !!!
    If all my batts, tested that close together -- I would Giggle and be happy as a lark !!
    Quit worrying, sounds really good to me -- but, you might exercise them, with just a small discharge regularly (10%)  and have a great weekend..  Bill H..
« Last Edit: July 10, 2005, 10:44:43 AM by Experimental »
« Reply #5 on: July 10, 2005, 11:24:52 AM »
Bill;
Yes, indeed, a difference of less than .1% is pretty negligible and could easily be from meter lead contact differences, etc.
« Last Edit: July 10, 2005, 11:24:52 AM by TomW »
Oops....
« Reply #6 on: July 10, 2005, 11:36:45 AM »
Decimal error there it is less than 1%.
Sorry.
T
« Last Edit: July 10, 2005, 11:36:45 AM by TomW »
zmoz
« Reply #7 on: July 10, 2005, 01:24:11 PM »
Like I said, I'm not worried about any problems with the batteries, I'm just wondering what would cause one to be a higher voltage. It wouldn't surprise me if there was any error in the meter, (it's just a $3 DMM from harbor freight) but shouldn't the error be the same for every battery, comparatively?
« Last Edit: July 10, 2005, 01:24:11 PM by zmoz »
PaulJ
« Reply #8 on: July 10, 2005, 06:13:23 PM »
   Temperature has quite an effect on battery voltage, even a small variation due to the different positions of individual batteries within a battery bank can make a difference. Does the battery in the middle show the higher voltage ? Anyway, no two batteries are ever completely identical, manufacturing tolerances I guess, and the older they get the more apparent this becomes.
   I run my house off a bank of 40 used Sonnenschein wheelchair batteries in a 48V series/parallel configuration, if the battery voltages within each series string are within .2 or .3V of each other I'm pretty happy.
  Paul.
   Off grid 4 months and still married.
« Last Edit: July 10, 2005, 06:13:23 PM by PaulJ »
JWilliams354
« Reply #9 on: July 22, 2005, 01:07:42 PM »
Paul what area do you live in? Just curious.
« Last Edit: July 22, 2005, 01:07:42 PM by JWilliams354 »
