Author Topic: End Charging voltage golf cart Batts  (Read 1927 times)
Geek
« on: August 01, 2005, 07:03:03 PM »
What is the max voltage I should charge a 6 volt golf cart batt to?
I have a 96 volt batt bank of 6 volt flooded lead acid bats. The charger says I should have a end voltage of 120 volts. that seems a little high to me.
What do ya think?
Thanks,
Geek
« Last Edit: August 01, 2005, 07:03:03 PM by (unknown) »
fishfarm
Re: End Charging voltage golf cart Batts
« Reply #1 on: August 01, 2005, 01:51:49 PM »
My Trojan Battery maintenance manual lists the following charger voltage settings for a 48V Flooded Battery system:
Daily Charge 57.6 - 59.2V
Float 52.8V
Equalize 62V
The 48V values are double the 24V settings( and 4 times the 12V), so just double them for your 96V system. It looks like the 120V is for an equalizing charge.
« Last Edit: August 01, 2005, 01:51:49 PM by fishfarm »
wpowokal
« Reply #2 on: August 02, 2005, 06:56:49 AM »
I concure withe the previous post,120v is very much in the ball park. If I had a charge controller for my 24V system I would set 28.7V as the float voltage, I use 31.5-32V as the equalising voltage.
Sandia National Laborities has done interesting reserch in this area, serch their site.
 http://www.sandia.gov/Renewable_Energy/renewable.htm
allan down under
« Last Edit: August 02, 2005, 06:56:49 AM by wpowokal »
wpowokal
« Reply #3 on: August 02, 2005, 09:26:21 PM »
Also check out http://www.homepower.com/magazine/downloads.cfmHomepower.
Click on bateries
allan down under
« Last Edit: August 02, 2005, 09:26:21 PM by wpowokal »
