Author Topic: Recovering dead batteries  (Read 2882 times)
henjulfox
« on: August 09, 2005, 03:06:28 AM »
At the office (elderly living building) we have a large battery backup system with 12
110 amp-hour AGM batteries. Seems that soon after they were replaced 2 years ago the
charging circuit popped a fuse so they had been periodically tested and used with
no charging. After yelling that testing involves looking at the volt meter mounted
on the front and after writing a check for $2,800 to replace them I offered to take
them home and mess with them. Worst case I'm out a few amps of electricity and a
sore back.
Had to walk past the beer fridge in the unloading process. Made it through the first
10 before the beer won. Each 12 volt battery measured less than 1 volt. Didn't know
you could get a battery that low...
Put a trickle charger and de-sulfinator on 4 in parallel in the garage and threw a
20 watt solar panel in the back of the car to charge the 2 in there. End of the
next day it was hot in the car, and the batteries were in full sun. Heat is bad for
batteries so I figured I had killed dead batteries. Got home and pulled out the volt
meter. Garage batteries charging for 24 hours were still below a volt. 2 Car
batteries charging from panel and well heated were at 5 volts. Hum...
Shortening up a long story - 3 weeks later each battery has spent a day or 3 in the
hot sun with a trickle charger and desulfinator. I unscrewed the tops to relieve
pressure and added a little water, just enough so that the material between the
plates looked damp, but no standing water. 10 of the 12 show resting voltage
(overnight with no charging) of between 12.85 and 12.91 volts. 2 won't get above 12.
I've had the 10 wired into my system for a week now and they are working great!
I wouldn't try this with good batteries but if you've got some due to be hauled to
the recycler it's worth a try. Note: I'm talking leave them out in the sun heat,
not pre-heat oven to 350 heat!
-Henry
« Last Edit: August 09, 2005, 03:06:28 AM by (unknown) »
cr8zy1van
Re: Recovering dead batteries
« Reply #1 on: August 08, 2005, 11:13:15 PM »
Good to hear of your success. I also have a UPS laying around the office, but mine appear to be in a little better condition. 3 of the 4 measure about 3~5 volts. I tried charging them with a conventional charger but to no avail, after about 8 hrs they were actually down a volt each.
I really want to revive these batteries. Could a little heat and time really do the trick? Since my office has already replaced the UPS unit, these are mine to do with as I choose. Does anyone have suggestions for kick-starting these back to life?
« Last Edit: August 08, 2005, 11:13:15 PM by cr8zy1van »
« Reply #2 on: August 08, 2005, 11:13:44 PM »
I know that in general, for most reactions, the rate of reaction increases with temperature.  Usually, the rate about doubles for each 10 degrees Celsius.  I don't recall ever reading anything about keeping batteries hot being good for them, conversly, I've heard that it is bad.  It's interesting, I wonder what the mechanism was.  Rich
« Last Edit: August 08, 2005, 11:13:44 PM by richhagen »
FishbonzWV
« Reply #3 on: August 09, 2005, 03:56:26 AM »
I'm trying to revive an AGM also. It's on the front porch tied to a solar panel and desulfator charger. Havn't seen much success yet. They get warm in the sun and voltage raises during charging but by morning it's back to 4.9v (6v battery). I also added water to rehydrate the mats. My next step is to try an equalizing charge with the tops off.
Glad you had the beer fridge close by...wouldn't want to hear you had keeled over from exhaustion. ;-)
Bonz
« Last Edit: August 09, 2005, 03:56:26 AM by FishbonzWV »
H.F.Fisher 1925-2007
Devo
« Reply #4 on: August 09, 2005, 06:51:25 AM »
I was at a scrap yard 2 months ago & picked up some cheap batteries , to my surpise  all the ones I took where near 13 volts sitting there & have worked fine , they also
had been in the hot sun  when I got them
Maybe something to that or maybe they were ok when they got left there?
Devo
« Last Edit: August 09, 2005, 06:51:25 AM by Devo »
« Reply #5 on: August 10, 2005, 04:50:09 AM »
I've heard that engine heat is the enemy of car
batteries...but maybe a slow gentle charge on a
deep-cycle battery combined with infrared and
ultraviolet rays of the sun is something else
maybe they even help the desulfation process..?
             ( :>) Norm.
« Last Edit: August 10, 2005, 04:50:09 AM by Norm »
hobot
« Reply #6 on: August 10, 2005, 08:55:06 PM »
Henry,
I'm fascinated and needful of the battery desulfator
spiker charger upper recover'r.
Visited your site, very informative but I'd sure
like to get more info on the basic principle  and
of course the circuit but also on a scale to handle
1700 ah 24V bank. Would rather find offtheshelf RF signal generator to fire a power pak but don't know if thats
fesible.
hobot
« Last Edit: August 10, 2005, 08:55:06 PM by hobot »
GeeWiz
« Reply #7 on: August 11, 2005, 12:05:48 AM »
Here is a site for Desulfators.  Easy to build, and they sell kits for those who do not have a lot of electronics stores around.
http://www.shaka.com/~kalepa/desulf.htm
Have fun,
Gw
« Last Edit: August 11, 2005, 12:05:48 AM by GeeWiz »
