Author Topic: Where Can I Obtain These Battery Connectors?  (Read 3247 times)
Slingshot
« on: April 18, 2008, 08:08:09 PM »
Shown below is the battery connection of a 28-AH, 24-V sealed aircraft battery.  I have several of these surplus batteries that I've pulse-desulphated/charged, and would like to use them in a solar/wind application.
What I need is an inexpensive source of mating connectors.  I've been using large alligator clips for charging and experimentation, but would like to have a cleaner arrangement for permanent installation into a renewable-powered workshop and Ham shack.
« Last Edit: April 18, 2008, 08:08:09 PM by (unknown) »
wiredwrong
Re: Where Can I Obtain These Battery Connectors?
« Reply #1 on: April 18, 2008, 02:51:51 PM »
I pretty sure the connector is called a "MS-3509" try an airplane salvage yard.
« Last Edit: April 18, 2008, 02:51:51 PM by wiredwrong »
Dozzer7
« Reply #2 on: April 18, 2008, 02:54:04 PM »
I might be able to round up a few old ones from the scrap pile that would still be usable for non aircraft use. Drop me a line with your address. S64F-at-MSN.com is mine
« Last Edit: April 18, 2008, 02:54:04 PM by Dozzer7 »
zeusmorg
« Reply #3 on: April 18, 2008, 03:07:05 PM »
 Buying that particular connector new would be more than replacing the battery  with a comparable deep discharge lead acid set, so I'd try some of your local airplane mechanics to see if they can salvage some old ones, or make your own.
« Last Edit: April 18, 2008, 03:07:05 PM by zeusmorg »
nick1234
« Reply #4 on: April 18, 2008, 07:38:21 PM »
if you do not find the connector and in a hurry you could make some with some thick wall brass tube drill to size cut a X at the end to a depth greater than the length of the post squish in for tight fit put a peace rubber hose  for insulation  connect wire at other end
enjoy
nick1234
« Last Edit: April 18, 2008, 07:38:21 PM by nick1234 »
« Reply #5 on: April 18, 2008, 10:41:12 PM »
Hi Slingshot.
I drilled and taped mine for 1/4-20 threds. I used a brass washer between the copper bus barr.
The bar is held to the battery post with 1/2" long 1/4- 20 brass bolts. This has been working great now for several years.
This is a 48 volt system.
« Last Edit: April 18, 2008, 10:41:12 PM by Jerry »
brightmae
« Reply #6 on: April 19, 2008, 12:36:40 AM »
do you have a photo?
please send to my email morr278@gmail.com
I will check it for you.
« Last Edit: April 19, 2008, 12:36:40 AM by brightmae »
Spaz
« Reply #7 on: April 19, 2008, 08:57:33 PM »
i think i saw a connector for that on EVparts.com  I don't remember the price
« Last Edit: April 19, 2008, 08:57:33 PM by Spaz »
mbeland
« Reply #8 on: April 21, 2008, 08:34:23 AM »
Pretty neat set up! Do I understand well, they are sealed so it means you don't have to water them up so that's why you can pile them up that way?
Martin
« Last Edit: April 21, 2008, 08:34:23 AM by mbeland »
Slingshot
« Reply #9 on: April 21, 2008, 09:28:22 AM »
Jerry,
I assume this means that the terminal posts are solid, not hollow?
« Last Edit: April 21, 2008, 09:28:22 AM by Slingshot »
Slingshot
« Reply #10 on: April 21, 2008, 09:30:12 AM »
Thanks, I was thinking about that also, because the terminals reminded me of the connection posts on my crackerbox welder.
« Last Edit: April 21, 2008, 09:30:12 AM by Slingshot »
Slingshot
« Reply #11 on: April 21, 2008, 09:30:43 AM »
Sending email now, thanks.
« Last Edit: April 21, 2008, 09:30:43 AM by Slingshot »
yuandrew
« Reply #12 on: April 22, 2008, 02:18:57 AM »
They could be an "Anderson" type connector. Look around on www.andersonpower.com
Anderson power products makes many specialized high current connectors; chances are good that they would have something like that.
« Last Edit: April 22, 2008, 02:18:57 AM by yuandrew »
« Reply #13 on: April 22, 2008, 09:14:05 PM »
Hi Slingshot.
Yep they are solid not hollow.
« Last Edit: April 22, 2008, 09:14:05 PM by Jerry »
« Reply #14 on: May 11, 2008, 02:03:37 PM »
My Curry eBike has receivers for the battery pack like that, but the pins are only 1 inch apart.
« Last Edit: May 11, 2008, 02:03:37 PM by dnix71 »
