Author Topic: Poll - What is your System Voltage  (Read 6145 times)
Woofer
« on: April 22, 2008, 12:31:22 AM »
I'm changing the front page poll . . .
What is your system voltage ?
« Last Edit: April 22, 2008, 12:31:22 AM by (unknown) »
Re: Poll - What is your System Voltage
« Reply #1 on: April 21, 2008, 06:58:06 PM »
If you can't see the POLL on the mainpage then you must Enable it.
On the Right-hand side of of this page is a box with your Username on it
In that box click "Display Preferences"
on the Display page at the bottom is a "Boxes" section
in this section is the box to check that will enable you to see the polls on the front page
While you are viewing the Display page you should change
Number of summaries to show = 50
Number of titles to show   =  50
This will enable you to see more than 8 stories at a time
Now Click the "Save Preferences" and enjoy your new settings
« Last Edit: April 21, 2008, 06:58:06 PM by wooferhound »
« Reply #2 on: April 21, 2008, 07:04:12 PM »
24 volt bank with-12 +12 section 24 volt charging with a 200 volt pulser
« Last Edit: April 21, 2008, 07:04:12 PM by tecker »
jacobs
144 Volt DC
« Reply #3 on: April 21, 2008, 08:20:01 PM »
We have 144 volt stand alone battery charging systems at BOTH our homes.
« Last Edit: April 21, 2008, 08:20:01 PM by jacobs »
yuandrew
« Reply #4 on: April 22, 2008, 02:13:12 AM »
12 volts (2 x 6 volt batteries in series) Runs pretty much anything you could plug into a car lighter socket.
« Last Edit: April 22, 2008, 02:13:12 AM by yuandrew »
« Reply #5 on: April 22, 2008, 02:47:51 AM »
Yes, it's that 'car lighter socket' thing that keeps me at 12V!
« Last Edit: April 22, 2008, 02:47:51 AM by DamonHD »
ruddycrazy
« Reply #6 on: April 22, 2008, 03:14:54 AM »
24 volts on the house, 24 volts with 2 battery arrays on the shed along with a bank of 10 nife batteries hooked up for 16 volts. Also 12 volts for some of the shed gear.
A man cant ever have enough RE in my opnion
« Last Edit: April 22, 2008, 03:14:54 AM by ruddycrazy »
jzeveney
« Reply #7 on: April 22, 2008, 06:32:17 AM »
12 volts via 15 (2 x 6 volt batteries in series)
« Last Edit: April 22, 2008, 06:32:17 AM by jzeveney »
valterra
« Reply #8 on: April 22, 2008, 06:42:27 AM »
Yep!  I can't see a reason for me to go to any other voltage, unless I could make 110 ac directly and store it in a battery. Let me know when they develop that.  <wink>
« Last Edit: April 22, 2008, 06:42:27 AM by valterra »
GeeMac
« Reply #9 on: April 22, 2008, 07:32:32 AM »
12
« Last Edit: April 22, 2008, 07:32:32 AM by GeeMac »
racer
« Reply #10 on: April 22, 2008, 10:52:36 AM »
Currently at 12v. Planning 24v -- have invertor and building motor conversion.
« Last Edit: April 22, 2008, 10:52:36 AM by racer »
elvin1949
« Reply #11 on: April 22, 2008, 12:53:19 PM »
12 volt   Can change to 24 volt if i find an inverter i can afford.
Elvin
« Last Edit: April 22, 2008, 12:53:19 PM by elvin1949 »
Tritium
« Reply #12 on: April 22, 2008, 01:08:16 PM »
12V, 24V, Planning 48V
Thurmond
« Last Edit: April 22, 2008, 01:08:16 PM by Tritium »
martin1
  • Country: se
« Reply #13 on: April 22, 2008, 02:08:27 PM »
48V
« Last Edit: April 22, 2008, 02:08:27 PM by martin1 »
rossw
« Reply #14 on: April 22, 2008, 05:14:48 PM »
  1. V (24 x 2V/500AH AGM) primary bank
  2. V (8 x 6V/220AH flooded lead/acid) secondary bank.
« Last Edit: April 22, 2008, 05:14:48 PM by rossw »
Spaz
« Reply #15 on: April 22, 2008, 06:08:11 PM »
12 volt dc on pv the house runs on 110 ac i think
« Last Edit: April 22, 2008, 06:08:11 PM by Spaz »
bob g
    • microcogen.info
« Reply #16 on: April 22, 2008, 06:25:18 PM »
originally planned for 12 volts, only because i can keep my cable runs short
and my loads very small relatively speaking.
changed up to a 24 volt plan because of finding three propane powered telecom 6kwatt gensets at a price i could not refuse.
if i keep planning and not doing, heaven knows what i will end up with!
actually i think i have settled on 24 and will stick with that voltage.
bob g
« Last Edit: April 22, 2008, 06:25:18 PM by bob g »
« Reply #17 on: April 22, 2008, 09:08:24 PM »
12 volt, 36 volt, 48 volt and 120 volt DC.
Several systems.
« Last Edit: April 22, 2008, 09:08:24 PM by Jerry »
thirteen
« Reply #18 on: April 22, 2008, 09:23:56 PM »
two large D Batteries 12 volt going to 24 volt this fall or next spring. small solar hopefully putting in micro hydro next year
« Last Edit: April 22, 2008, 09:23:56 PM by thirteen »
MntMnROY 13
KEG
« Reply #19 on: April 22, 2008, 09:30:54 PM »
Howdy Yall :-)
24 Volt = 140 1.4 V Nife batts series and paralell ( not done yet, more to go )
amph = I'm not smart enough to figure that one out.
I don't think the hot water solar panel makes any power !
« Last Edit: April 22, 2008, 09:30:54 PM by KEG »
snuffy
« Reply #20 on: April 23, 2008, 12:46:39 PM »
400AH @ 24vdc,  1750w UPS as an inverter.  Runs my shop stuff except the 1.5 hp motors.
« Last Edit: April 23, 2008, 12:46:39 PM by snuffy »
snowcrow
« Reply #21 on: April 24, 2008, 04:37:48 AM »
  I'm using 12vdc and small gas generator for 120vac.
Snow Crow
« Last Edit: April 24, 2008, 04:37:48 AM by snowcrow »
kenl
« Reply #22 on: April 24, 2008, 05:12:07 PM »
24v with 2 arrays of agms 400ah main house kept charged by 880w of solar. 12v with 1 array agms 160ah in the shop addition kept topped off with a 108v dc turbine hooked directly to the bank via a diode. Oh yeah and 800 ah of 12v spare batteries.
kenny
seemed like a good idea at the time
« Last Edit: April 24, 2008, 05:12:07 PM by kenl »
SteveCH
« Reply #23 on: April 24, 2008, 06:41:33 PM »
12 v.
« Last Edit: April 24, 2008, 06:41:33 PM by SteveCH »
brianschanafelt
« Reply #24 on: April 25, 2008, 10:19:54 PM »
500ah lead acid, 12v, 1200w inverter runs computer, big screen, and lights no problem
on a hugh piggott 8' turbine
« Last Edit: April 25, 2008, 10:19:54 PM by brianschanafelt »
howlet
« Reply #25 on: April 27, 2008, 03:47:44 PM »
Hi All, 48 volts.  JB
« Last Edit: April 27, 2008, 03:47:44 PM by howlet »
