Author Topic: Astron power supply as a charger?  (Read 1949 times)
Luminosity
« on: January 02, 2006, 12:31:53 PM »
I just acquired a free batch, slightly used, 12 pcs. x T-105's but only have a dinky 10 amp battery charger.  Can a use an Astron variable 50 amp power supply, just the same as a charger? Is there a formula as to how much amperage and voltage to equalize x amount of batteries?
« Last Edit: January 02, 2006, 12:31:53 PM by (unknown) »
wpowokal
« Last Edit: January 02, 2006, 05:35:40 AM by wpowokal »
wildbill hickup
Re: Astron power supply as a charger?
« Reply #2 on: January 02, 2006, 06:16:11 AM »
Where in Vermont are you. I'm near St. Johnsbury.
« Last Edit: January 02, 2006, 06:16:11 AM by wildbill hickup »
Luminosity
« Reply #3 on: January 02, 2006, 09:09:30 AM »
Thanks for the links!
Fayston, Vermont
« Last Edit: January 02, 2006, 09:09:30 AM by Luminosity »
drdongle
« Reply #4 on: January 02, 2006, 01:37:01 PM »
Simple answer is yes as long as you can adjust the output to 13.8 V.
« Last Edit: January 02, 2006, 01:37:01 PM by drdongle »
