Author Topic: What size of turbines do I need.  (Read 773 times)
jrx3
« on: April 12, 2005, 03:57:15 AM »
I have purchased a Ametek 20VDC Permanent Magnet Motor for use in a Wind Generator.  I am thinking about using a Savonius blade design. The question I have is, with an aspect ratio of 2 to 1 I would like to build 2' wide by 4' high units, how many of these would I need to run this motor/generator in a moderate wind speed environment. Thank you for your information and help.
« Last Edit: April 12, 2005, 03:57:15 AM by (unknown) »
dimitar
Re: What size of turbines do I need.
« Reply #1 on: April 12, 2005, 12:43:16 AM »
How many metars is the rotor of turbine?
« Last Edit: April 12, 2005, 12:43:16 AM by dimitar »
« Reply #2 on: April 12, 2005, 07:40:10 AM »
last week windstuff ed gave the  savonus power formula, check (vawt torque fomula) the tricky part is estimating the force required to rotate the actual geni at a particular rpm under load. a modular system of construction would be ideal if you could work it out.
« Last Edit: April 12, 2005, 07:40:10 AM by electrondady1 »
« Reply #3 on: April 12, 2005, 07:45:43 AM »
it's in the mechanical section.
« Last Edit: April 12, 2005, 07:45:43 AM by electrondady1 »
dimitar
« Reply #4 on: March 13, 2008, 07:35:34 AM »
You can define the size of turbin using the WindTurbo software, from
http://www.partenovcfd.com/software.html
« Last Edit: March 13, 2008, 07:35:34 AM by dimitar »
