I have proved it to myself by using hard drive magnets any buying and using commercial neo's. Hard drive magnets are just as good as bought neo's
If you bother to spend a little extra time pulling hard drives apart you can end up with magnets just as good as bought neo's.
Mind you you need to have a supply of several hundred hard drives (go and talk to your local junk yard people).
Here is how I do it.
It is easy and no fuss and works every time (1 in 20 you might stuff up).
To bend the backing plate use a spanner (shifter) on each end of the backing plate and twist gently.
The backing plate will bend and the magnet stays straight. Lift it gently so as not to damage the nickle coating too much.
I pile the mags onto a metal plate up to the height I want the magnet to end up at.
The magnetism holds the pile nice and firm so no clamps needed.
To see where to cut exactly just sprinkle a few grains of iron filings on top of each magnet pile. You will see a nice straight line which is where you cut them.
Cut each pile with an angle grinder. The thin cutoff discs make it very easy.
They are non magnetic and cutting a 5 high pile stack takes about 20 seconds (never actually timed it but it is quick).
When you have finished you just turn over one half of the pile and hey presto, there is one magnet for your genny.
The mag rotors (dual rotors)shown here have produced 500 watts into 12 volt batteries.
The prop blades are 1.5 metres radius - recycled old wooden stairs.
3 phase 70 turns per coil, 2 in hand 1.00 mm diameter copper wire recycled from microwave transformers.
If you havn't done it yourself, don't knock it until you've tried.
Mick S
