i haven't put a lot of thought into this but the idea has some merit if the bugs are worked out. i was thanking that when the sail is blown to a full out position that the pole will spring back and the sail will fall and fill again to restart the cycle. in a light wind the pvc pole will bend and pull back to activate the recoil start spring. almost any movement of the pole or sail will cause some power to the flywheel. the unit should track the wind by the force on the sail causing the whole unit to rotate. i also thank that if the sail is hinged slightly off center at the top that it will yaw in and out of the wind causing some action in the recoil system. i just had two twelve inch strap hinges broken on one of my shops bouble doors when it was cought by a heavt gust of wind and slammed into the stop that i was holding the door open with while working inside, the wind has some real force against a solid object. this is just something to try one day because i have lots of room for windmills and some folks reading this post dont have any. enjoying myself, pepa.
