Thanks guys for your comments. I use epoxy RTU 1:4 mix for the rotors - lets leave that subject.
For the stators I have used epoxy Versamid 1:1 with... umm... you wont like this.... NO fiber. Just plain epoxy. And I am making the stators 8mm thick now. I did get some warping on an earlier model, and the latest one has some aluminium beading set in the epoxy around the outside, which I hope will stiffen it.
Does the ATH additive you mention stiffen the epoxy, or just improve heat dissapation? And do you use glass fiber as well?
And if you use glass fiber, what form do you use? Woven matting shoved down into the mould, or do you mix the epoxy with chopped strands and just pour it all in?
Thanks again for your response,
South Easter
http://windpower.org.za
