Author Topic: Opera house  (Read 1081 times)
(unknown)
Opera house
« on: December 10, 2004, 06:06:51 PM »
I am in same boat with plasma cutter that you replied to in fact or fiction post. was there a troubleshooting sequence that you used, and any other tips you found after repairing the plasma cutters. thanks. caos
« Last Edit: December 10, 2004, 06:06:51 PM by (unknown) »
Opera House
Re: Opera house
« Reply #1 on: December 10, 2004, 02:38:36 PM »
Most of the problems are obvious due to the nature of currents involved.  The IGBT and diode modules crack open.  Some of the diode modules have internal SCRs to turn the main power on and off.  Problems usually happen in the power supply section that is often a switcher are often of a common variety. These include sorted bridge rectifier, supply cap or switching transistor.  If it gets beyond that, the problems won't be very easy.  Some of these boards aren't supported very well and get cracks.  What make and model do you have?
« Last Edit: December 10, 2004, 02:38:36 PM by (unknown) »
