Author Topic: Dimensions Unlimited  (Read 864 times)
christopher
« on: May 22, 2005, 06:12:34 PM »
Just found at the dump a Dimensions 48 volt 2100 watt output inverter, opened it up all looks fine inside. Hooked it up to batteries and Ac charge line and it shows no indication of power at all.  I was wondering if anyone is familiar with these as it has a remote hook-up which is not with it and if these lines have to be shorted for the onboard function to work?
Thanks for any ideas.
Christopher
« Last Edit: May 22, 2005, 06:12:34 PM by (unknown) »
nanotech
Re: Dimensions Unlimited
« Reply #1 on: May 22, 2005, 01:11:54 PM »
Dumb question, but did you check the fuses?  :)
« Last Edit: May 22, 2005, 01:11:54 PM by (unknown) »
Bryan1
« Reply #2 on: May 22, 2005, 05:43:22 PM »
If you found it at the dump and it doesn't work I think you'll find it could of had a voltage spike on the input. That would blow all the output fet's and render the unit useless. Or you could contact the maker and get a quote on repairing it. I blew my 1700 watt inverter the same way and it cost $165 to repair, lucky my inverter was made in Oz and I got to talk with the bloke that made it.
Cheers Bryan
« Last Edit: May 22, 2005, 05:43:22 PM by (unknown) »
« Reply #3 on: May 26, 2005, 02:20:27 AM »
 If nothing else, look at all the great parts you have now :)
« Last Edit: May 26, 2005, 02:20:27 AM by (unknown) »
christopher
« Reply #4 on: May 26, 2005, 05:03:51 AM »
thanks guys for the replays, e mailed the co they say it will not work without the remote wires will have to be changed at factory.long way to ship from bahamas to st paul MN 60 lbs.good parts :)
 thanks Christopher
« Last Edit: May 26, 2005, 05:03:51 AM by (unknown) »
