3 phase 'axial-flux' alternator.
6
magnets - Surface Field: 3490 Gauss; 1/2" x 1/4" x 1/8" thick, glued to the 5cm diameter circle metal sheet in flower shape.
Wooden 5.5cm diameter base with 18 ray 1.5 x 0.7 cm holes for stator coil (6 per phase).
1200 number of loops of #38AWG
magnet wire per phase (200 per ray)
Gap between magnets and stator is about 2mm.
The design looks like
this, although 2 times smaller...
1 phase ac voltage measured corresponds to the calculation by this formula with 4 cycles per second:
Vmax = NARPB/2
Where:
· N is the number of loops of wire.
· A is the area enclosed by a loop of wire, in square meters.
· R is the rotational velocity of the magnets, in cycles per second.
· P is the number of magnet poles per cycle.
· B is the strength of the magnetic field of each pole, in Tesla.
and equals ~ 0.5 VAC
