Author Topic: Battery bank questions  (Read 958 times)
(unknown)
« on: April 20, 2007, 10:13:10 PM »
I have four 12V batteries in parallel with a 750W continuous inverter and I'm wondering if my #6 jumpers are large enough.  Would I be able to connect the inverter between batteries instead of at the end of the bank to more evenly distribute current through the jumpers?
P.S. With an inverter, how do you determine (roughly) the total DC amps it will draw based on the wattages of the AC loads plugged in?
« Last Edit: April 20, 2007, 10:13:10 PM by (unknown) »
kurt
    • website
Re: Battery bank questions
« Reply #1 on: April 20, 2007, 05:08:22 PM »
it is called watts law
amps * volts = watts
so in your case devide 750 by 12 and that will be the aproxament amp draw of the inverter at full load not counting inverter efficency and all that.
« Last Edit: April 20, 2007, 05:08:22 PM by (unknown) »
wpowokal
« Reply #2 on: April 20, 2007, 06:25:30 PM »
Go here and calculate, gives table then a calculator,
http://www.powerstream.com/Wire_Size.htm
allan down under
« Last Edit: April 20, 2007, 06:25:30 PM by (unknown) »
Lumberjack
« Reply #3 on: May 04, 2007, 11:12:52 AM »
Assuming you want to hook it up in Parallel like this:
B-B-Load-B-B
Yes each side will only carry half the current, however should it become connected like this:
B-B-B-B-Load
then you will be undersized and the cables will overheat.
For the amount of cable and its cost I would stick to using the full load rather then praying no one mis-wires it and risking a fire. If you have any plans for expansion I would in fact recommend upsizing a bit.
« Last Edit: May 04, 2007, 11:12:52 AM by (unknown) »
