Author Topic: LED tail lights  (Read 1951 times)
(unknown)
LED tail lights
« on: December 17, 2007, 09:10:14 AM »
My son as fitted LED tail lights to his Renault Clio (1.2 2001)When they are switched on and the engine is started they go off!! With the engine running they can be switched on and off no problem. The original bulb type work fine. I have even wired them in sharing the same supply and earth, the bulb type remain lit whilst the LEDs go off and will not come back on until the switch is re operated.
I have replaced the battery on the car but this as made no difference, again as soon as the car is started the LEDs go off.
Any suggestions would be much appreciated.
Many Thanks Tiggsy
Not really an automotive forum here. Resectioned.
« Last Edit: December 17, 2007, 09:10:14 AM by (unknown) »
veewee77
Re: LED tail lights
« Reply #1 on: December 17, 2007, 06:01:29 AM »
Depending on how they are wired, it could be that the voltage is too low when the car is just on and not started. LEDs require a minimum voltage to light up. If there are too many in series, and the voltage is too low, they will not light. Then when the car is started, the alternator raises the voltage high enough to light the LEDs.
Doug
« Last Edit: December 17, 2007, 06:01:29 AM by (unknown) »
finnsawyer
Re: LED tail lights
« Reply #2 on: December 17, 2007, 09:56:33 AM »
It sounds to me like you must have some type of solid state (safety?) circuitry before the LEDs.  When the car starter turns over the voltage to the tail lights drops.  This causes the solid state circuitry to shut off the lights.  It then requires recycling (i.e. hitting the switch) to turn the lights back on.  One solution would be the addition of a second battery, not affected by the starter.  Not a very satisfactory solution, though.
« Last Edit: December 17, 2007, 09:56:33 AM by (unknown) »
finnsawyer
Re: LED tail lights
« Reply #3 on: December 17, 2007, 09:59:21 AM »
Or maybe it's in the switch itself.
« Last Edit: December 17, 2007, 09:59:21 AM by (unknown) »
Re: LED tail lights
« Reply #4 on: December 17, 2007, 01:41:39 PM »
You could put the old bulbs back in
« Last Edit: December 17, 2007, 01:41:39 PM by (unknown) »
disaray1
Re: LED tail lights
« Reply #5 on: December 17, 2007, 05:24:54 PM »
My thoughts exactly Woof.
« Last Edit: December 17, 2007, 05:24:54 PM by (unknown) »
Opera House
Re: LED tail lights
« Reply #6 on: December 18, 2007, 09:23:31 AM »
A 100 ohm resistor in parallel with the lamps might be enough current to hold the electronic circuit on.  A lot of effort, but you are going for a look.  Starting a vehicle normally drops the voltage a couple volts.  LEDs are usually stacked in series and act like a zener, below a certain voltage the lamp no longer conducts. Don't understand the need for a hold circuit like this, but having owned a Pugeot understand the French are apt to do anything.
« Last Edit: December 18, 2007, 09:23:31 AM by (unknown) »
Cloaked User
Re: LED tail lights
« Reply #7 on: December 18, 2007, 05:18:46 PM »
I wasn't going to say anything, but since you brought it up, I had a Renault for several years long ago. It was a tough and efficient little car, and comfortable too, but boy was it weird! I had lots of electrical misadventures with it, including a small fire. You had to get parts from the nearest Jeep dealer then. That was long before anyone thought of LED taillights, so I have no advice that hasn't already been suggested.
That car got 32 mpg on the highway, 25 years ago. I drove it hard for about 90,000 miles at a net cost of under 13 cents per mile. Purchase price, interest, taxes, license, insurance, fuel, tires, repairs, duct tape, everything. My present work truck costs just about 13 cents per mile for fuel.
« Last Edit: December 18, 2007, 05:18:46 PM by (unknown) »
Cloaked User
Re: LED tail lights
« Reply #8 on: December 18, 2007, 05:22:35 PM »
Oops, dadgummed typo! My present wheels cost me about 23 cents for a mile's worth of fuel. Yikes!
« Last Edit: December 18, 2007, 05:22:35 PM by (unknown) »
elvin1949
Re: LED tail lights
« Reply #9 on: December 24, 2007, 09:10:27 PM »
I get 50 miles to the hamburger on my bike.
Elvin
« Last Edit: December 24, 2007, 09:10:27 PM by (unknown) »
