Oil sucks, wind blows.
I was browsing allelectronics.com for surplus, and came across som 40 Amp solid state relays 3-32v trigger at 25 mA for 15$. I'm buying some of them to use with my controller , and a load dumper.
These typically go for a lot more money, and the nice thing about them is the low trigger voltage/low trigger current / high current switching (can be triggered by most homemade controllers with 5V-12V)
Having screw terminals is a plus, as you don't have to worry about how thick a PC board trace needs to be to handle the switched current.
http://www.allelectronics.com/make-a-store/item/SSRLY-42/40-AMP-SOLID-STATE-RELAY/1.html
http://www.cosmo-ic.com/ProductDetail-H.asp?title=Solid%20State%20Relay
It looks like it's a triac and good for dumping on the AC side of a turbineor on the AC output side of an inverter.
Cosmo does have DC MOSFET types too, but they are very low current.
There are some decent DC SS Relays out there that I have seen in the past.
boB
I'm gonna stick to my original plan and dump as needed from DC side, i just couldn't pass these up though.
