Author Topic: monotube boiler  (Read 3516 times)
greenkarson
monotube boiler
« on: May 08, 2010, 06:54:20 PM »
Thinking about abandoning my tank boiler and building a monotube boiler.  But having trouble rapping my mind around the water supply. Can i use a electric supply pump and if so does it have to be at the same psi as the max psi that I need for steam. Or is there some sort of valve i can use so i can use a lower psi pump.  Was hoping to use a 12v pony pump if possible
 any thoughts or ideas about monotube boilers?
thanks
