Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Other
Battery charging with slow speed diesel
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Battery charging with slow speed diesel (Read 3437 times)
bamfords54
Newbie
on:
May 28, 2010, 07:25:10 PM »
Hey everybody, I have a 5 1/2 h.p. bamfords diesel I would like to use to charge 8 L16 batterys at 24V. Would i be better off using an alternator or a generator? I have an outback inverter now, with a 10KW 34 H.P. 4 cylinder diesel genset that uses way to much fuel. thanks in advance.
Logged
bob g
Hero Member
8.8kwatt idi diesel thermal conversion unit
Re: Battery charging with slow speed diesel
Reply #1 on:
May 28, 2010, 07:34:24 PM »
you will be better off with an alternator, "if" you do it right you can get very good efficiency too.
check out the pdf file at
http://www.microcogen.info/index.php?topic=157.0
the white paper outlines how to get remarkable efficiency from an off the shelf 12volt alternator to charge at 28.8vdc
which is just what you need. the example produces 2.88kwatts of power which is within the capability of your engine.
the unit runs at a documented 80% efficiency which places it way ahead of simply using a standard off the shelf 24volt alternator
and likely ahead of simply plugging in a charger into a AC generator.
it would be a good match in my opinion
bob g
Logged
www.microcogen.info
and a SOMRAD member
Rabrsniver
Jr. Member
Reply #2 on:
May 28, 2010, 08:00:32 PM »
Hi Bob,
I'm interested in reading your paper, but your link doesn't show anyway to access the pdf.
Can you post it to the Otherpower Board somehow, so I can access it.
Thanks,
John
Logged
Print
Pages: [
1
Go Up
« previous
next »
Other
