Author Topic: onan generator head  (Read 4838 times)
mbk
onan generator head
« on: June 08, 2010, 10:40:50 PM »
hi all im not sure if this is the place for this question or in wind or newbie but anyway you can move it if need be. my question is i have a few onan generators that are good ones but i have one with a bad motor and a good head. i was wondering if this would be a good one to rewind or put rare earths in an convert for a wind turbine.its a 4kw and it rpm is 1800 its 110ac i know i wont get 110 ac out of it but maybe to rectif to 12 or 24 volt dc or if i had to use a gear box with maybe with big blades 18 or 20 feet maybe or is it worth playing with it would be for battery chargeing .thanks for any replys
        max
luv2weld
Re: onan generator head
« Reply #1 on: June 09, 2010, 10:39:44 AM »
Max,
Personally, I would think about hooking that head up to a single cylinder Listeroid engine.
Here is a link to what DanB did with his.
http://www.otherpower.com/fuking.html
You will probably have to figure out how to put a bearing and pulley on the motor end of the shaft
after you separate it from the dead engine.
If you run it at 600 rpm with a 3 to 1 pulley ratio that will turn the head at 1800 rpm.
Right where it needs to be.
Ralph
mbk
« Reply #2 on: June 09, 2010, 11:09:25 AM »
Thanks Ralph
  I read through Dans page on his generator that looks like a good setup for this head too I think Ill go in that direction thanks again
                                                          Max
luv2weld
« Reply #3 on: June 09, 2010, 12:42:30 PM »
Sorry, I should have included a couple more links.
http://utterpower.com/index.html
This should be information overload. Enough to keep you reading for days!!!
Ralph
