Author Topic: electric Recumbent Tricycle  (Read 13304 times)
GoVertical
« on: November 01, 2010, 07:23:24 AM »
Greetings, The PMA can also function as a motor. Using the fabrication techniques illustrated on this site and other to create 2 PMA's, One to generate power and one to act as a motor for a Recumbent Tricycle. Should the PMA's be the same size, be different sizes, and if they where different sizes which one should function as the motor or generator to gain the best performance from human power? Comments Welcome.
kilroyOdin is not here ;)
SEMPER FEROX
Re: electric Recumbent Tricycle
« Reply #1 on: November 01, 2010, 08:46:14 AM »
What is the purpose?
It only requires one to do both jobs.
"regenerative braking"
GoVertical
« Reply #2 on: November 01, 2010, 08:18:14 PM »
Greetings, I confused the pedal assist system for a generator. After I reviewed the video I am really not sure if there is generator in the system.
The other video is just a recumbent Trike design. Would it make sense to add a generator to a electric bike?
 http://www.youtube.com/watch?v=Zmwd1aup68Q
http://www.youtube.com/watch?v=qiv4aDolVaI
SEMPER FEROX
« Reply #3 on: November 01, 2010, 08:37:33 PM »
I do not believe it would make ANY sense to add a generator to an electric bike.
There are too many losses to make it efficient.
Some electronic devices will allow the motor to act as a generator when it is possibly a good idea.
The electronic devices are complex, and best purchased from a regenerative braking circuit manufacturer.
« Reply #4 on: November 02, 2010, 02:08:55 PM »
you should use one large one, it will be lighter and more efficient than two smaller ones.
taylorp035
« Reply #5 on: November 16, 2010, 03:03:31 PM »
You could do what this guy did and put a brushless motor on his.  I know the Castle Creations controllers will send power back to the batteries, so you could set up braking quite easily.
http://www.youtube.com/watch?v=WKAMus3oSdw
Warning:  This guys has 20kw.... so there is way too much power.  The people on endlesssphere.com are much better at designing and building these things.
