Author Topic: ***SOLD OUT***RPM Meter Kit for Wind Gens***SOLD OUT***  (Read 2799 times)
BrianSmith
« on: August 02, 2011, 07:31:42 PM »
I built a little PCB to measure wind generator RPMs.  I have seven more PCBs and made a kit you can order to build one for yourself.
First come, first serve till they're gone.   ::)
- It take a single phase input from the generator and outputs a 0 - 5VDC output that represents 0 - 500 rpm.
- You can use a volt meter, analog meter or data acquisition system to display or log the RPM.
- The output can be scaled if necessary with an extra resistor load on the board.
- There is an LED on the board that shows the RPM by brightness as well.
- Supports 12V, 24v, 48V generators and higher outputs with resistor change.
- Supports generators with 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, or 24 poles.
- Powers from 8V - 16VDC, about 10ma nominal current.
Here is a link with some pictures and more info about it:  https://sites.google.com/site/rpmmeter/
Brian Smith
« Last Edit: August 19, 2011, 05:28:48 PM by TomW »
BrianSmith
Re: RPM Meter Kit for Wind Gens
« Reply #1 on: August 19, 2011, 04:40:46 PM »
These are SOLD OUT.  If you want one, you are welcome to build more PCBs, I will provide you the gerbers and the SW for the processor.
Not planning on building any more.
Brian Smith
