Author Topic: Active Pitchcontrol  (Read 334331 times)
midwoud1
Re: Active Pitchcontrol
« Reply #462 on: August 31, 2015, 01:52:26 PM »
 Hi Arch.
Between 180 - 350 Rpm it's running safe. No high centrifugal forces. 600 Rpm is dangerous.
The amount of sunwheel teeth here  is 37 to keep the hub compact. Disc diam. is 280 mm.
More or less teeth gives the same result to move the blades synchronous.
The generator here has 5 kg copper  9 coils  and 2x 12 magnets  to make 800 watt  ( Hugh Piggott  3 meter windmill )
With a microcontroller you can switch easy to change the behavior with software, of rpm and charge power.
But it is not a must . The Rpm counter has a variable voltage output ,use that as a switch command trigger between the desired Rpms.
Tension level active.
The actuator makes steps of 0,5 seconds.
Rgds. Frans.
midwoud1
« Reply #463 on: December 20, 2015, 03:23:41 PM »
To all Fieldliners   Merry Christmas and a happy NewYear
                                Frans.
« Reply #464 on: December 21, 2015, 03:17:13 PM »
Merry Christmas Frans.  ~ks
mbouwer
« Reply #465 on: December 22, 2015, 03:25:37 PM »
Frans,
We heard that some guys want to go further on the basis of your prototype.
That's good news.
Regards Rinus
mbouwer
« Reply #466 on: April 09, 2016, 03:49:04 PM »
Blade suspension for the new mock up.
mbouwer
« Reply #467 on: April 19, 2016, 07:04:09 AM »
Blade suspencion completed.
mbouwer
« Reply #468 on: September 18, 2016, 05:03:01 AM »
In 2011 this Midwoud topic began and sometimes there were enthusiastic reactions.
I wonder if other windmill builders have gone further with this concept of active pitch.
midwoud1
« Reply #469 on: September 18, 2016, 06:34:45 AM »
There was some criticism on the actuator control system.
Imagine if something fails in wiring or powersupply , Does the blade-angle follow a sudden windgust ?
It all worked perfect as a prototype.
I think its time for a bigger windmill.
mbouwer
« Reply #470 on: September 19, 2016, 02:56:00 PM »
Exchange of ideas could improve the design.
mbouwer
« Reply #471 on: October 22, 2016, 04:40:09 PM »
Now I am trying to make a radial direct-drive generator. Starting with this package
with outside diameter 364 mm
« Reply #472 on: October 22, 2016, 07:24:01 PM »
14 inch rotor..neos or ceramic mags ? looks like a good start..made one useing a exersize bike flywheel..glued down some cheap ceramic mags to that--made a stator  from a couple pieces of plywood-with a metal curved flatbar for the coils--metal insert in each coil hole...20-15  3phase   55winds two in hand  #17 wire..maxed out close to 400 watts with currant gearing...
whats your layout ?
Adriaan Kragten
« Reply #473 on: October 23, 2016, 04:53:36 AM »
In my report KD 437 of 2010 I describe a pitch control system for the 2-bladed rotor of VIRYA-15 wind turbine. I have made certain choises resulting in a design for which the mechanism is shown in figure 7 of KD 437. Other starting conditions will result in a different design. In chapter 6 of KD 437 I give some arguments for certain choises and these arguments may be of help if someone wants to design his own system. KD 437 can be copied for free from my website: www.kdwindturbines.nl at the menu KD-reports.
mbouwer
« Reply #474 on: October 23, 2016, 02:11:52 PM »
To start I would like to make a small low-speed synchronius generator with separate exitation.
The laminations are now modified and have 96 poles.
« Reply #475 on: October 23, 2016, 11:28:16 PM »
Why did you cut off the outer edge of the ring???  :(
The available flux path is now cut by 1/4.
You will increase saturation, and self-heating, and have less steel to absorb the heat through.
mbouwer
« Reply #476 on: October 24, 2016, 06:30:46 AM »
The intention is to make a small scale Enercon generator. (http://www.enercon.de)
Later on I want to grind  the lamination core to the inner diameter of 295 mm
Now I have made a fixed axle pin.
« Reply #477 on: October 24, 2016, 02:33:56 PM »
I don't see how cutting down the teeth ID will help.  You have choked the MMF to 1/3 or 1/4 of its original capability, by increasing the magnetic path resistance.
The power curve will flatten out very early.  The medium range power will suffer from low efficiency and the high end will run hot.
« Reply #478 on: October 24, 2016, 02:49:20 PM »
So your going for field coils on the rotor not mags ?  Once it's started should power it self like a car alt.
Adriaan Kragten
« Reply #479 on: October 25, 2016, 06:44:46 AM »
I have had contact on a Dutch forum with Mr. Brouwer about his generator. The original stator stamping has 48 grooves and is ment for an 8-pole asynchronous motor. Mr. Brouwer has not reduced the outer diameter but removed the original 48 grooves completely and replaced them by 96 much smaller grooves. So he has increased the inner diameter. He will make a 32-pole armature with 32 separate electro magnets. For a 32-pole armature, the pole pitch is 11.25 degrees. For an optimal coil, there are three stator spokes within each coil. Half of the magnetic flux flowing through these three spokes bends to the left and half bends to the right when the flux arrives at the bridges in between the bottom of a groove and the outside diameter. The width of a bridge must be at least a factor 1.5 times the width of a stator spoke to prevent that the steel at the bridge is saturated earlier than the steel at the spokes. In the photo it seems to me that the bridge is wide enough.
If the original stamping with 48 grooves would have been used for a 16-pole generator, it would be allowed to reduce the outer diameter such that the bridge has half the original width. Then you get the same strength of the magnetic flux in the bridge as for the original stamping and an 8-pole generator.
mbouwer
« Reply #480 on: October 25, 2016, 09:45:57 AM »
Now after this mock-up,
how to make a better start trying to make a real nice small Enercon-like generator?
« Reply #481 on: October 25, 2016, 02:55:02 PM »
Thank you for the explanation Adriaan!  I did not realize that he had done that.
Yes I see now that there is adequate flux path when the pole count is increased to 32.
mbouwer
« Reply #482 on: October 26, 2016, 05:33:56 AM »
On the Dutch Ecologieforum   http://www.ecologieforum.eu/viewtopic.php?f=40&t=2566&start=1095
there are more photos.
Also many Enercon turbines around here.
« Reply #483 on: October 26, 2016, 11:17:02 AM »
What kind of draw will all those field coil have ?
mbouwer
« Reply #484 on: October 26, 2016, 01:04:25 PM »
Hiker,
I would like to ask people with expertise: please respond to this question.
« Last Edit: October 26, 2016, 01:12:33 PM by mbouwer »
mbouwer
« Reply #485 on: December 04, 2016, 03:23:30 PM »
To find the knowledge for a design and to make a small direct-drive synchronius generator with separate exitation is going to take some time.
In the meantime I modificated a ceiling fan to a small generator.
« Last Edit: December 04, 2016, 03:45:01 PM by mbouwer »
mbouwer
« Reply #486 on: December 10, 2016, 03:57:31 PM »
Small size. Fun to do.
mbouwer
« Reply #487 on: December 23, 2016, 09:18:01 AM »
To all windmillfriends,
Merry Christmas and a lot of energy for the coming year
« Reply #488 on: December 23, 2016, 10:24:17 AM »
AND a VERY MERRY Christmas to you as well.
mbouwer
« Reply #489 on: January 07, 2017, 05:20:49 AM »
More details of this test setup on Ecoforum  http://www.ecologieforum.eu/viewtopic.php?f=40&t=2566&start=1140
« Reply #490 on: January 07, 2017, 06:39:19 PM »
https://www.youtube.com/watch?v=kSqNOVECurc          just a vid of my radial bike alt...mag powered ..
mbouwer
« Reply #491 on: January 10, 2017, 05:11:16 AM »
Nice device. I guess you used iron in your coils and can you tell something about that?
« Reply #492 on: January 10, 2017, 11:26:15 AM »
just a on going hobby with me....its a 20-15  3 phase alt..coils two in hand #17 wire..hit 400 watts at  28v ..briefly ! Using a 400 watt aircraft landing light..coils are mounted to a iron band..with iron inserts in the coil holes...mags are ceramic .with small neos glued to the top of the neos as well..mounted a auto rad. Fan ..just for a load..works great for that..hits up to 8 or 9 amps at around 20v..plus it keeps you cool as well..coils are a bit over kill at two in hand...makes a good batt. Charger as well..chugs along at 5 amps 13v fairly easy...grandkids like to work out on it..makin Sparks fly..or breaking water down into gas..HHo...💥
« Reply #493 on: January 10, 2017, 11:29:02 AM »
Mags are ceramic with neos glued to the top !
mbouwer
« Reply #494 on: January 15, 2017, 04:30:24 AM »
The ceiling fan generator is back on the test stand.
If I drive it now with another motor. Does power come off it?
