Author Topic: Active Pitchcontrol  (Read 225042 times)
mbouwer
Re: Active Pitchcontrol
« Reply #810 on: July 30, 2017, 03:01:21 AM »
Yaw bearing hub.
« Reply #811 on: July 30, 2017, 08:38:59 PM »
Nice...if your going for heat...ide go with the thicker mags..the thin mags lose their stringht under a large load...due to the coil having a reverse field when they pass over the coil..coils..
mbouwer
« Reply #812 on: July 31, 2017, 03:40:40 AM »
My intention now is to make a well-arranged test stand and have, together with windmillfriends, a critical look at all components.
mbouwer
« Reply #813 on: August 01, 2017, 05:41:55 AM »
Yaw axle. The heavier the nacelle the more reinforcement sheets I would like to add.
mbouwer
« Reply #814 on: August 02, 2017, 03:16:23 AM »
Next issue: the yaw drive.
mbouwer
« Reply #815 on: August 03, 2017, 03:01:45 AM »
As a side note:
How about shaping the lamination core out of disassembled transformer laminations?
« Last Edit: August 03, 2017, 04:29:15 AM by mbouwer »
mbouwer
« Reply #816 on: August 04, 2017, 03:30:31 AM »
The yaw bearing should turn less than 1 rpm. I could use this cordless screwdriver motor ( 180 rpm ) with one more reduction.
mbouwer
« Reply #817 on: August 05, 2017, 04:20:24 AM »
After mounting an extra planetary reduction of a cordless drill I have a good outgoing speed.
But I think the torque is overdone, in fact the motor could be much smaller and it's too complicated this way.
I want to search for a smaller engine with the proper reduction.
« Reply #818 on: August 11, 2017, 07:12:46 PM »
I am really happy this thread is still in tacked.
« Reply #819 on: August 11, 2017, 07:22:06 PM »
I agree...wating  on latest progress report...😜
mbouwer
« Reply #820 on: August 13, 2017, 12:03:54 PM »
As an aside relating to reply #796
I converted my electric powered ride on mower to a forklift like shape. The swing arm pivot of the power supply cable is attached to the top of the mast. Easier steering and riding around now.
« Last Edit: August 13, 2017, 12:09:16 PM by mbouwer »
« Reply #821 on: August 13, 2017, 03:22:24 PM »
No doubt you get a lot of second looks in that rig.
« Reply #822 on: August 13, 2017, 05:33:53 PM »
Lawn mower on steroids...with that you could trim the tops of hedges..or even give someOne..a flattop crew cut..😜
frackers
  • Country: nz
  • Is it finished yet?
« Reply #823 on: August 13, 2017, 06:08:55 PM »
You could tackle some REALLY long grass with that...
mbouwer
« Reply #824 on: August 14, 2017, 06:02:17 AM »
Actually I like this way of mowing because it brings less damage to the environment.
My big goal is to be able to mow with the energy of my, in cooperation with windmillfriends built, small windturbine.
mbouwer
« Reply #825 on: August 15, 2017, 07:27:46 AM »
I myself also would like to be involved in others who build a small mill.
mbouwer
« Reply #826 on: August 16, 2017, 07:17:14 AM »
The slide yaw bearing of reply #810  I would like to change to a double row ball bearing.
2 outer raceways turned / grinded in the hub.
« Last Edit: August 16, 2017, 12:48:44 PM by mbouwer »
midwoud1
« Reply #827 on: August 17, 2017, 04:21:06 AM »
Few years ago I made a yaw drive  prototype.
Chain sprockets , Worm reduction , Cordless drill-motor.
Never used it in real situation .
Very content with the active pitchcontrol system.
mbouwer
« Reply #828 on: August 18, 2017, 06:33:28 AM »
Really interesting project. Is it still available for home constructors for further build?
The "axle" of the yaw bearing.
mbouwer
« Reply #829 on: August 20, 2017, 03:59:43 AM »
shortening the spacers = iserting more rollers = heavier load possible.
mbouwer
« Reply #830 on: August 20, 2017, 04:21:20 AM »
This construction is derived from reply # 810  Weight: 1747 grams.
I would now like to make a simpler improved version with a slightly larger sprocket.
midwoud1
« Reply #831 on: August 20, 2017, 06:22:29 AM »
I am quite good at working with metal ,but making a slew-bearing I am too young for it.
mbouwer
« Reply #832 on: August 20, 2017, 08:29:15 AM »
Cooperation is the answer.
mbouwer
« Reply #833 on: August 24, 2017, 06:07:02 AM »
Shaping the new light yaw bearing. Filling ring at the holes.
mbouwer
« Reply #834 on: August 25, 2017, 02:11:17 AM »
Found these pinions ( 3 Euro ) Now I need to shape an appropriate sprocket on the yaw bearing.
mbouwer
« Reply #835 on: August 26, 2017, 04:55:03 AM »
Welded teeth at the circumference. Following is the internal assembly.
mbouwer
« Reply #836 on: August 27, 2017, 06:26:45 AM »
Inner ring+roller-raceways.
Thinking another and easier method might be to make the yaw bearing from composite material.
Or 3D printing.
