Author Topic: Watt's Up meter  (Read 958 times)
Watt's Up meter
« on: October 12, 2011, 01:21:01 PM »
My Watt's Up meter displays this:
################          ( ......well they aren't pound signs they're black rectangles)
instead of watts and volts n' stuff like it's
suppose to when I hook it up ....about 10 months past the
year warranty....any place fix these or do you just toss them ? :(
  At that rate it cost me about $3 a month... ::)
Anyone else have this problem with theirs or just my usual run of luck?
Having fun in Conneaut...except for this !   :D
Rover
Re: Watt's Up meter
« Reply #1 on: October 12, 2011, 02:08:34 PM »
Mine is doing something similar. Its only affected a few on the left at this point but bad enough to not be able to read those images.
Sometimes I can see through to the digit , sometimes not.
No idea if it can be fixed easily.
Rover
Re: Watt's Up meter
« Reply #2 on: October 12, 2011, 05:52:15 PM »
Mine looks like that looking at it with my polarized prescription sun glasses on. As do many flat type screen displays. Probably not what you have. I always like to power down flakey devices for a few hours then reconnect to make sure it is not some weird symptom of a spike or other electrical glitch.
Its cheap and often ineffective.  ???
Re: Watt's Up meter
« Reply #3 on: October 12, 2011, 06:36:30 PM »
This has happened about a week ago I use it on my Pedgen.....lucikily I
also have a digital 7 function speedometer hooked up to the pedgen so I know
at a speed of 3.3 mph (small 12 inch dia. wheel) that I get 1 watt hr. every 2
minutes when charging a 12 volt battery.....and it shows actual time pedaling.
I guess it's pretty accurate enough.....I feel just as tired when pedaling for 100 min.
and equivalent of about 5 miles, as I do when it shows 50 watt/hrs.
Still doing research on my 14.4 v cordless drill batteries and the double stuff ones do
last a lot longer than the singles....Duh !    ::)
Norm.
Hey thanks for the suggestion Tom.
(back to the pedgen.....couple a miles more to go....)
Re: Watt's Up meter
« Reply #4 on: October 18, 2011, 01:38:57 PM »
Do those meters have a Brightness or Contrast adjustment ?
Re: Watt's Up meter
« Reply #5 on: October 18, 2011, 03:06:21 PM »
Mine does not.
BUT it's the Version 2
Re: Watt's Up meter
« Reply #6 on: October 21, 2011, 09:37:12 AM »
In the meantime as far as pedaling I've figured out that the digital bike meter works out
with the 12 inch wheel at .1mile is is just about eqivalent to 1 watt/hr. with the ratios of the
alternator. the only problem will be if I change setup.
Bruce, I'm gradually learning how to make those Paks.....for the pllastic tubes a strip
glues on very nicely with super glue ....lining the edge up like a flap appling the glue very
carefully on the edge with a toothpick only takes about a  minute for the seam to set
up once it makes contact and it's just like welded.... I get a little over zealous with the
heat when it comes to shrinking  tho' when I get to the edges and shrinks out of shape...
but starting to get the hang of it now....
Norm.
