Author Topic: my first project  (Read 16716 times)
boogerbr549
my first project
« on: April 17, 2012, 05:46:12 PM »
well their finally up and running and feeding the grid. those r 2hp 120v 21amp dc motors wired in series feeding a 300 watt GTI.
Re: my first project
« Reply #1 on: April 17, 2012, 06:43:13 PM »
neat.
lots of room for more.
i thought you had written , "giver" on the side of the building which is Canadian for try real hard.
what is the dia. of the individual rotors.
boogerbr549
« Reply #2 on: April 17, 2012, 08:15:53 PM »
the 6 blades r made from sch 35 pvc at 20 inchs mounted on a 6 inch 3/16 plate steel hub. working on three more should b up in a few weeks.
boogerbr549
« Reply #3 on: April 17, 2012, 08:33:00 PM »
the word  is Gower, their mounted on top of the garage. their mostly pretty quit but in 25 mph and up wind they sound like an airplane. going to need a 500 watt GTI that handles higher voltages because the 300 disconnects at 32volts. still learning I have $300 in everything including the GTI and the disconnect.
birdhouse
  • Portland, OR USA
« Reply #4 on: April 18, 2012, 12:11:26 AM »
not to be a safety sally, but is that GTI from china (via ebay?)??  if so, it's sketchy, and most times illegal activity.
just a thought.
adam
boogerbr549
« Reply #5 on: April 18, 2012, 08:00:55 AM »
LT-S300G-WDL  US seller. well the electric company meter reader came into my garage to check the hook up and to check the GTI to make sure it has Irland protection which it does. he liked it and they do allow net metering. u said "via ebay" does that mean that items on ebay r all from china? or that their all unsafe?
boogerbr549
« Reply #6 on: April 18, 2012, 08:07:41 AM »
define sketchy. and tell me why it would b illegal? and what would make it unsafe?
« Last Edit: April 18, 2012, 08:14:38 AM by boogerbr549 »
« Reply #7 on: April 18, 2012, 01:41:30 PM »
Here, the in USA anything you connect to the grid MUST be UL certified, otherwise you risk killing a power poll person,
 IF you go look at the specs of this piece of crap, you'll see the AC freq is way out of control range for even the worst USA gird line.
A US seller doesn't mean squat, you buy it and connect it to the grid, and hurt someone besides yourself you go to jail, simply put.
Here's a *bay link go read 2/3rds the way down read the specs, show them to a lineman and wait for their reaction. 8)
boogerbr549
« Reply #8 on: April 18, 2012, 01:56:07 PM »
if it does not detect a live grid it will not power up. when I turn the breaker off that goes to the GTI the red comes on and I checked it with my volt meter and there was no power comeing out. turn the breaker on and I have power. Idont c the link.
« Last Edit: April 18, 2012, 01:58:44 PM by boogerbr549 »
« Reply #9 on: April 18, 2012, 02:02:58 PM »
boogerbr549
« Reply #10 on: April 18, 2012, 02:13:47 PM »
what do u recomend?
« Reply #11 on: April 18, 2012, 04:03:59 PM »
I would go with one that is fully UL compliant, these are findable almost as easily as these "others". Just more expensive due to the extra safety built in, outback quickly comes to mind, but there are others.
Best of luck
I do wish you would post closer pic of the mills with more detailed info.
Blades, normal output/mph the build up of each one, that type of info is what helps others.
PS>> part of your handle reminds me of Hee-Haw from back in the day you in GA?
« Last Edit: April 18, 2012, 04:07:15 PM by Bruce S »
boogerbr549
« Reply #12 on: April 18, 2012, 04:15:30 PM »
I watched that show all da time. i left more info the newbie section.
boogerbr549
« Reply #13 on: April 18, 2012, 05:10:08 PM »
« Last Edit: April 18, 2012, 08:15:29 PM by boogerbr549 »
boogerbr549
« Reply #14 on: April 19, 2012, 08:30:33 AM »
this would have to include gas power generators as well.
copperhead1971
« Reply #15 on: March 26, 2013, 09:19:17 AM »
It does say it has Island Protection , I be leave that means it will shut down when the main power goes out, right?
« Reply #16 on: March 26, 2013, 01:41:40 PM »
no furling ?  i always liked windstuffnows downwind mill..dont have to worry about blade strikes on the tower..
i belive he off set it a bit so it would turn out of the wind in high winds..
   http://www.windstuffnow.com/main/test_page.htm
« Reply #17 on: March 26, 2013, 03:12:08 PM »
Anything grid connected has to be UL listed, I don't see UL listed on that GTI so I would not use it. Means it hasn't been tested to prove it won't kill someone or burn your house down. Someone else on here had a bad experience with one of those almost starting his house on fire.
boogerbr549
« Reply #18 on: March 27, 2013, 07:29:43 PM »
they have 360 clearance.  I have now added a 48 volt 15 amp turbine and is wired in, and went up to a bigger GTI, had good wind from sept, to current cut my electric bill in half, back in july when we had the big storm here we had wind speeds of 85 mph on the roof top they sounded like a bunch of jets, lol ;D
