Author Topic: Flat plate garage door solar collectors  (Read 4605 times)
wewantutopia
« on: November 13, 2012, 11:24:40 PM »
Anybody know of such a product?   Could be water or hot air.   For south facing garage doors, this is a huge untapped surface area.   Should be an easy product to manufacture since the door panels are already thick hollow cavities.
Just brainstorming...
Woodstock, IL 60098
thirteen
Re: Flat plate garage door solar collectors
« Reply #1 on: November 15, 2012, 06:43:40 PM »
With some stiffening of the frames and cushioning for the panels and flexable wire a person should be able to make a solar door. But take the basketball hoop off the front of the garage.
MntMnROY 13
« Reply #2 on: November 15, 2012, 11:33:24 PM »
You don't have to buy one. Instead, you can stick with the DIY spirit of this site, and build one yourself:
http://www.builditsolar.com/Projects/SpaceHeating/SolarGarageCollector/VinylSolarDoor.htm
wewantutopia
« Reply #3 on: November 16, 2012, 08:45:28 AM »
I did read over that post in the past.
I was hoping there was some others who had made the ACTUAL garage door into a solar collector.
Woodstock, IL 60098
SteveCH
« Reply #4 on: November 16, 2012, 09:57:31 AM »
Are you going to disconnect the water lines every time you want to raise the doors? I am not seeing this. Air heating would work ok, if you get good sunlight hitting the vertical surface of the doors when closed. But, water?
I just finished building a roof-mounted collector, by the way, following, mostly, the information on BuildItSolar. It has been hooked up now for about two weeks, very happy with the performance.
« Reply #5 on: November 17, 2012, 01:17:15 AM »
Make sure to let Gary know about any observations you have, good or bad.  He loves improving his projects with reader feed-back.
What do you have in mind?  Modify a segmented door or a solid one?  Separate panel entirely?
