Author Topic: wire sizing  (Read 15019 times)
thirteen
wire sizing
« on: February 12, 2013, 01:06:28 PM »
I thought I could go right to a chart for the capacity of amps on wire size. I cannot find the chart I used before.  I have a 24 v system and need to go either 420 ft or 375 ft from the solar panels to the control room. 5 panels 240 w 24v. ea panel is fused at 10 amps. 2 wires from the combiner box to controler. Could some one direct me to a chart. 13
MntMnROY 13
madlabs
Re: wire sizing
« Reply #1 on: February 12, 2013, 01:46:49 PM »
This what I use:
http://www.powerstream.com/Wire_Size.htm
HTH,
jonathan
thirteen
Re: wire sizing
« Reply #2 on: February 12, 2013, 01:50:08 PM »
thank you 13
MntMnROY 13
phil b
Phil
Simen
  • Country: no
  • Grimstad, Norway
Re: wire sizing
« Reply #4 on: February 13, 2013, 01:01:07 AM »
I made a cable calculator a while back where one can calculate needed size for a given length/load/max-loss, or loss in a given length/load. All in metric, though... ;)
A simple program that need little: http://mwlmf.net/prog/CableCalc11US.zip
thirteen
Re: wire sizing
« Reply #5 on: February 13, 2013, 03:27:32 PM »
5 - 24v 240w panels. The distance is about 375ft. 114.3 m.  Does the wires from the combiner box on a solar system to the controler both need to be the same size or can I have the neg side be smaller? Since I will not be running a ground wire from the solar panels to the controler panel. This cropped up in my mind. Trying to save a few bucks or jsut thinking to much. I will ground the panels right at the pole.  13
MntMnROY 13
Larsmartinxt
  • Country: no
Re: wire sizing
« Reply #6 on: February 13, 2013, 05:19:06 PM »
Both needs to be the same sizeas the same amount of current goes trough both wires
thirteen
Re: wire sizing
« Reply #7 on: February 14, 2013, 02:36:54 PM »
Yes! I thought about it after I sent it, I was letting $$ get in my way?
MntMnROY 13
