Hi Doug,
Yup, I made a full sized drawing but I will admit that getting all 15 coils to conform to it was a bit of a challenge (at this size [6.25" magnet circle] things don't need to be off much to cause headaches ... considering 20 polls and 15 coils).
Coils are all wound and I made a jig with 15 dowel pins in a circle to form the coil assembly nice and uniform.
Taped all the coils together (that was a pain) and placed some epoxy where they join so I now have a coil set that is manageable and conforms to my magnet circle.
Made a 3 layer stator mold from 1/4" thick hardboard (stator should turn out ~1/4" thick plus a sheet of fiberglass each side) and the coil assembly fits in the mold nicely.
When the epoxy sets up a bit more, I'll solder my coils per phase and make some connection sleeves from some small copper tubing, lay in a sheet of fiberglass, place the coils, make the pour, lay in another sheet of fiberglass and clamp 'er down good. (I'll tape the edges and wax the mold for easy release).
As you can imagine, this mini axial flux is turning out to be nearly as much work as a full sized unit (and, of course, will not produce as much power).
I'm enjoying the process, however, and am on a very low budget so I'll be happy with the results even if the output is not generous.
(My goal is to light some LED's for the deck, if I can charge my mouse batteries as well ... I'll be a very happy camper
Wish me luck on the pour.
Arc out
