Author Topic: Welding and fabrication  (Read 4077 times)
JW
  • Development Manager
    • Flashsteam.com
« on: February 07, 2014, 08:54:51 PM »
Hi All,
I'm about to embark on a journey, going to purchase two new welders a Mig and  Tig... Also im going to use a stick welder, its a machine from the 80's more details on that to come.
Here's the Tig now this is a solid-state rated to 200amps.-
http://www.ebay.com/itm/231135664390?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Then this Mig welder-
http://www.ebay.com/itm/141008456082?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Also-
Torch set
http://www.ebay.com/itm/390763166732?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
gloves-
http://www.ebay.com/itm/331100702765?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
helmet-
http://www.ebay.com/itm/321220268706?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Arc rods (6010)-
http://www.ebay.com/itm/290905570551?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I will update this post to give my feedback on the different items listed
Re: Welding and fabrication
« Reply #1 on: February 07, 2014, 09:17:27 PM »
two points:
http://www.ebay.com/itm/TILLMAN-50-TOP-GRAIN-SPLIT-COWHIDE-MIG-GLOVES-LARGE-/331123577737
these take the cake. not nearly as heavy as the traditional 15$ welding gloves, but i don't need the thermal insulation if i'm using my head, and they are soft enough for Tig work.
second: 7014 rods. unless the price difference matters and you don't care what the welds look like.
http://www.ebay.com/itm/Weldcote-7014-X-1-8-Stick-Welding-Electrode-10-Lb-Pkg-/251399193627
6010's should go a lot cheaper than 4$/lb...
http://www.ebay.com/itm/ESAB-1-8-inch-6010-weld-rod-12-5-lb-tube-/151211523782
« Reply #2 on: February 08, 2014, 11:53:54 AM »
Those Tillman gloves look nice but they should have been longer. I used a cheap stick welder occasionally and don't want my forearm burned by splatter.
birdhouse
  • Portland, OR USA
« Reply #3 on: February 08, 2014, 01:04:36 PM »
ive used that miller 211 before.  didn't care much for the auto set feature, but loved the machine aside from that.
welded up a custom thumb for an excavator with it from 1/2" plate steel.  hasn't broken a weld yet...  (knocking on wood).
adam
JW
    • Flashsteam.com
« Reply #4 on: February 08, 2014, 03:40:45 PM »
I know the 6014 has about 60,000 psi tensile strength, is the 7014 higher?
« Last Edit: February 08, 2014, 03:48:43 PM by JW »
« Reply #5 on: February 08, 2014, 04:24:52 PM »
there is quite a bit of difference between the 70's and the 60's rods. yes, they are 70,000 psi, 60,000 psi rods.
grinding down 6011 rods are like cutting through rebar, 70 rods leave a much harder metal behind.
7014's give you a weld that looks close to a 6013, with a bit of undercutting at the edge of the bead, but with much more penetration.
I use 7018's because that's what I can buy locally, but I don't like the slag it leaves and the weld doesn't look as nice.. but that might just be my welder.
6010's i've never used, i'd imagine they are just like 6011's which are great for welding rusted rebar together and that's about it. they supposedly have great penetration, but the surface of the weld left behind is so full of inclusions and slag i don't understand how you can weld over the top of a 6011 rod with something else without leaving inclusions.. unless of course you grind off the top of the weld.. which is probably what some people do.
6013's and 7014's don't have that problem because the slag cracks off on its own in once piece and leaves a relatively smooth bead.
« Reply #6 on: February 08, 2014, 07:59:22 PM »
I struggled with welding until I got a Miller MIG:
http://www.ebay.com/itm/Millermatic-180-Auto-Set-Machine-907312-NEW-/360855164583?pt=BI_Welders&hash=item5404a4d6a7
Now I can happily work all day without fussing.
I also don't use the auto-set any more.
JW
    • Flashsteam.com
« Reply #7 on: February 08, 2014, 08:20:06 PM »
Ive done a lot of mig welding part of what im getting is this mig-
