Author Topic: MY WIND TURBINE 60 VOLTS AT HIGH SPEED?  (Read 2274 times)
captainward
« on: July 08, 2014, 06:42:10 PM »
I WANT TO CHARGE 4-12 VOLT BATTERYS BUT MY WIND TURBINE SOMETIMES PUTS OUT 60 VOLTS WHEN THE WIND KICKS UP
WHAT WILL THIS DO TO THE BATTERYS? AND IS THERE A WAY TO KEEP THE VOLTAGE FROM THE WND TURBINE AT 12 VOLTS. OR CAN I JUST LET DO ITS THING?  tHANKS :o)
Re: MY WIND TURBINE 60 VOLTS AT HIGH SPEED?
« Reply #1 on: July 09, 2014, 02:55:20 AM »
Just let it do its thing. This is perfectly normal, the open circuit volts will just follow wind speed.
When connected to the battery it will just supply an increasing current with wind speed. Until the battery is fully charged and gassing you needn't worry. If you reach gassing volts the battery voltage will then rise excessively, either use more power than you are producing, shut the turbine down or fit a diversion charge controller.
Wind turbines should not be run on open circuit, the speed can be excessive and as you found the volts can get to dangerous levels in high wind.
captainward
« Reply #2 on: July 09, 2014, 10:22:06 AM »
Flux:
Thanks soooo much for your knowledge I Thanks you .....:O)
