Author Topic: Matched capacity battery pack question  (Read 1756 times)
micropv
« on: August 09, 2014, 02:31:50 PM »
So going through some AA nimhs to create a few small packs, I am attempting to match as closely as possible reserve capacity using my BM200 charger/tester.  Just a quick question though, lets say I have a AA with a tested capacity of 1000mah, and another at 1200mah. Do I consider this a 1000mah capacity pack, or do I multiply the two and then divide by two for an average?
not a big deal, was just curious
Re: Matched capacity battery pack question
« Reply #1 on: August 09, 2014, 03:27:06 PM »
My assumption is that you have to work to the capacity of the weakest cell in a series set since you must not over-discharge that weakest one
« Reply #2 on: August 10, 2014, 12:59:33 AM »
Damon is correct. The weakest cell is the capacity of the pack. Overdischarge will reverse the polarity of the weakest cell and ruin it.
micropv
« Reply #3 on: August 10, 2014, 04:21:35 PM »
Thanks guys,
Kind of what I thought, always good to get others opinions.  Matching capacity is an incredibly slow process, I am not sure it is worth the effort really.
A set of 4 batteries purchased 3 years ago (factory advertised as 2100mah) and always used in a 4.8v configuration with many, many cycles now.
Started the charge/discharge/test function earlier this morning.
Thanks again
