Author Topic: I still exist.  (Read 15396 times)
DanB
    • otherpower.com
I still exist.
« on: December 22, 2014, 10:15:55 PM »
It's been a tricky year.  More to come.  Stuff that happened 2 days ago.... 24' turbine on a 135 give or take tower (forgot), producing peaks so far over 7kW yay!
« Last Edit: December 22, 2014, 10:23:57 PM by DanB »
DanB
    • otherpower.com
Re: I still exist.
« Reply #1 on: December 22, 2014, 10:29:40 PM »
The alternator has 24" magnet rotors with 24 poles.  We're building a bigger one now (to be AC coupled on this off grid system)... w/26" rotors (24 poles) it should cut in at about 200V, and probably have a 25' give or take rotor.
Re: I still exist.
« Reply #2 on: December 22, 2014, 10:43:07 PM »
Hey there!  Glad to see you're still at it.
That's a big power plant, man.
DanB
    • otherpower.com
Re: I still exist.
« Reply #3 on: December 22, 2014, 10:54:29 PM »
This was the first incarnation.... with 20' blades and a 13' long tail boom.  Now she has 24' blades and a 16' tail.  Hope it doesn't burn out.
Re: I still exist.
« Reply #4 on: December 23, 2014, 02:55:45 AM »
hows the gang doing back up in the canyon--have you sold out the old digs-and living in town ?? try to follow you on facebook know and then..........
ontfarmer
Re: I still exist.
« Reply #5 on: December 23, 2014, 07:33:39 AM »
Glad to hear and see things still happen. Wait for updates.
                                         Ontfarmer
kitestrings
Re: I still exist.
« Reply #6 on: December 23, 2014, 08:12:02 AM »
That's a beast.  Nice to hear from you.  ~ks
kitestrings
Re: I still exist.
« Reply #7 on: December 23, 2014, 08:12:29 AM »
Re: I still exist.
« Reply #8 on: December 23, 2014, 08:31:18 AM »
well, .....merry Christmas !
Re: I still exist.
« Reply #9 on: December 23, 2014, 02:25:55 PM »
Yes, Happy Christmas and a better New Year than recent ones...  %-P
DanB
    • otherpower.com
Re: I still exist.
« Reply #10 on: December 23, 2014, 02:43:52 PM »
So far this machine is behaving well, furling reliably at about 6kW from what I hear.  Cannot wait to get up there in a couple of weeks and build the slightly larger machine.  That one will be 900' from the batteries, probably cutting in at 200V, we'll likely run high voltage DC to some new Morningstar MPPT controllers... or... (if they don't have those ready for us yet) it'll be high voltage AC through Ginlong inverters.  Should be fun stuff anyhow!  Damon... yes, thank you... hopefully this next year is better than the last two.  Sick of floods and fires and other stuff.  Nice to have some big wind turbines to work on.
Re: I still exist.
« Reply #11 on: December 23, 2014, 05:47:50 PM »
Those are massive! Hope you get the store back online soon too, couple things I wanted to buy in the coming year.
Re: I still exist.
« Reply #12 on: December 24, 2014, 03:34:15 AM »
Nice to hear what you are up too.  I'm still around as well, but very busy now days which makes it difficult to have a lot of fun (aka build stuff).   I know they take quite a bit of effort to write, but I always enjoy reading your build posts, and that massive machine sounds interesting.   Rich
DanB
    • otherpower.com
Re: I still exist.
« Reply #13 on: December 24, 2014, 09:29:59 AM »
I'll do an extensive write up on the machine soon after we know more about its behavior.
ontfarmer
Re: I still exist.
« Reply #14 on: December 24, 2014, 06:39:37 PM »
Any idea of wind speed for 6 KW?
 My 20' makes power in low wind.
DanB
    • otherpower.com
Re: I still exist.
« Reply #15 on: December 24, 2014, 10:18:15 PM »
We do not have data acquisition on this tower yet... it will happen though.  And I had to leave the site before seeing much wind at all on it so....  no I really have no idea except that so far it's making everybody happy ;-)  (sometimes I think it's best to leave things that way and not to get too much information but we don't learn much that way...)
MattM
Re: I still exist.
« Reply #16 on: December 26, 2014, 02:56:49 AM »
The scaling up in size has to be putting wood to its limits.  Do you do anything to lighten the blades, like hollowing out cores?
clockmanFRA
  • Country: fr
    • Renewable Energy creation
Re: I still exist.
« Reply #17 on: December 26, 2014, 04:26:40 AM »
I don't know 'MattM', my first 12 footer, Hugh Piggotts design, was a set of lightweight Western Red Cedar blades, each approximately 6lbs, which after nearly 5 years have given me no trouble except a fresh coat of paint every year. But the leading edge some times losses paint and I get a bit of water ingress and that slightly unsettles the balance a bit.
After that all my 12 footers have fiberglass blades, each approximately 9 to 11lbs, with the same design. These were experimental and I am now on some Mk4b's. I now ensure that the internal rib is well joined to the root mounting block, a failure area, and the blade really totally foamed filled. Heck of a job getting each blade back into the mould quick, 6 seconds, and clamped down before the foam distorts the original shape before setting.
Another problem with hollow blades, especially with fiberglass, is water/moisture ingress and balance problems.
If I did blades again they wood definitely be solid wood.
Trouble is, getting good Red Cedar here in Europe is very difficult.
DanB
    • otherpower.com
Re: I still exist.
« Reply #18 on: December 26, 2014, 07:17:01 AM »
I think we can go fairly larger with solid wooden blades, they're not that aweful heavy.  (that said I have no plans to go much bigger.... maybe 25' for the next turbine I'll be working on in 3 weeks)
Still to date (knock on wood) I've not had a blade failure from wooden blades unless something hit it or it hit something.
ontfarmer
Re: I still exist.
« Reply #19 on: January 17, 2015, 08:10:35 PM »
Hope that machine is making you smile?
DanB
    • otherpower.com
Re: I still exist.
« Reply #20 on: January 22, 2015, 08:10:31 AM »
Yes it does make me grin.  I'm actually at the site now building a slightly larger one.  This 24' turbine is so far well behaved and producing a good bit of energy.  This is a tricky off grid site with some serious loads (a 120' square foot free standing walk in freezer, a 120 square foot walk in fridge... commercial kitchen, 3 buildings with in floor heating etc....).  Oh... and 7 different kinds of homebrew that just come out of the wall!  (it's kind of a fun place to play).
Re: I still exist.
« Reply #21 on: January 22, 2015, 08:59:41 AM »
Sounds terrible Dan.  I hope they don't for you to check the homebrew for safety too often!  B^>
gww
Re: I still exist.
« Reply #22 on: January 22, 2015, 10:46:31 AM »
Beer coming out of the walls, when do you find time to build anything?
gww
klapeto
Re: I still exist.
« Reply #23 on: February 04, 2015, 08:48:47 AM »
Hi there! Nice work!
How much does each magnet rotor disk weight?
thanks
Kostas
scotty
Re: I still exist.
« Reply #24 on: February 05, 2015, 12:23:58 AM »
Dan
The 25.5' rotor is coming along very nice....can't wait to get it flying....and be part of that....
Scotty
Smithson
Re: I still exist.
« Reply #25 on: March 30, 2015, 01:31:56 PM »
Hi:  Are you the same Dan that wasi on the tv show "Brainstormmers" or is that the other Dan?   I know that is not the same turbine because it was on a 45 foot tower and a rebuild anyway.  Thanks Arch
ontfarmer
Re: I still exist.
« Reply #26 on: December 23, 2015, 04:44:36 PM »
Any information on the turbine of how it is behaving?
   Merry Christmas to every one.
JW
  • Development Manager
    • Flashsteam.com
Re: I still exist.
« Reply #27 on: August 25, 2023, 11:59:59 AM »
These are the Dans, bought this forum from them a long time ago.  The actual database is huge this place is a great resource
Yianie123.
Re: I still exist.
« Reply #28 on: October 25, 2023, 03:26:42 PM »
I just saw your pics.  Looks great.  I would love to know more about the particulars, like magnet sizes, wire size, anything you would like to share.  Email me direct if you can:  aka Yianie123.
« Last Edit: October 26, 2023, 09:55:18 AM by Bruce S »
Re: I still exist.
« Reply #29 on: October 26, 2023, 09:55:59 AM »
Yianne123;
I took your email address off from here , there are way too many trolls and spammers looking for just what you had up here  :o.
IF you want to put it back on, knowing the risks , merely reply and put it in the reply.
That will also let the Moderators know you wish it to be left here.
It's usually better to send a PM to the individuals with your email address and such.
topspeed
  • Country: fi
Re: I still exist.
« Reply #30 on: November 04, 2023, 04:34:44 AM »
Hello !
Is there snow in Alaska like there is here in northern Finland about 4-6 inches ?
I find you project very inspiring and cool.
Ulrich Hütter
