Author Topic: 48V alternator (ICE driven)  (Read 37402 times)
madlabs
« on: December 24, 2014, 12:27:55 AM »
Hi All,
I want to build another small engine/alternator charger. Problem is that I am now on 48V I can't find any alternators for less than a kilobuck. It's gotten to the point where having a 12V alt rewound or having my buddy in Shanghai see what he can find for me. Any leads or suggestions? I'll be building the controller for it, all I need is the basic alt.
Thanks!
Jonathan
Re: 48V alternator (ICE driven)
« Reply #1 on: December 24, 2014, 10:11:54 AM »
There are 48v AirX's. Maybe pick up a used one and mount it. They have a pretty good front sealed bearing.
madlabs
« Reply #2 on: December 24, 2014, 10:45:43 AM »
Dnix,
Too small and no field coil for control. I'm looking to pull 3kW or so from the unit, or around 60 amps. So I'd like to find something capable of around 100 amps so as to have some overhead.
Thanks!
Jonathan
wpowokal
« Reply #3 on: December 24, 2014, 01:47:14 PM »
You could build a Hugh Piggot design, they don't have to be wind driven, but you will need a regulator.
I have a Mecc Alte 110v alternator 55-0-55 long coupled to a small Lister, I rectify the AC output for my 48v bank, control is Allanmatic but a regulator could be used. I only use one of the 55v windings as my little Lister can do 1.75 Kw (it's a little tired).[img]http:/
They are sold under many labels.
Allan
madlabs
« Reply #4 on: December 24, 2014, 04:52:32 PM »
Hmm, now that's an idea. I'd have to look into controllers. I'm guessing that they are more complicated than controlling an alternator - pwm'ing a field coil is just so easy.
I'll go take a look into that right now, thanks for the suggestion.
JOnathan
« Reply #5 on: December 24, 2014, 05:21:47 PM »
24 volt 100 amp automotive style alternators are readily available on Amazon etc. run a pair in series?
« Reply #6 on: December 24, 2014, 06:27:38 PM »
Some John Deere alternators are 48v, but even used they aren't cheap. $2k new.
http://www.ebay.com/itm/John-Deere-TCA21706-TCA17247-48v-Alternator-8000-E-Cut-Reel-Mower-Generator-/291277057596
$900 on eBay used.
48v alternators are normally telecom equipment in the US.
http://www.ebay.com/itm/ALPHAGEN-DCX3000-36-48V-DC-GENERATOR-NEW-WITH-ACCESSORIES-041-028-10-/321611424684
New, complete 36-48v genset including the engine for $1100 shipped.
madlabs
« Reply #7 on: December 26, 2014, 12:53:28 PM »
That Deer alt looks great. Spendy though. I like the look of that genny too, it is exactly what I am intending to build, right down to the choice of motor. Very tempting, I know it will cost me more than that to build one. Of course, building it is fun, but then goodness knows I have enough to keep mt busy anyway....
Many thanks!
JOnathan
PaulJ
« Reply #8 on: December 27, 2014, 07:27:01 PM »
A 12V externally regulated alternator works fine at 48V if you spin it fast enough, make sure the internal diodes are rated at 100V though.
I use an old Ford 12V 55A alternator geared up about 3.5:1 on a 16 hp motor, energise the field off a separate 12V battery.
The dump load on the rest of the system takes care of regulation in my case, wasteful I know but I only use the generator infrequently in winter for bulk charging.
Paul.
madlabs
« Reply #9 on: December 28, 2014, 12:28:38 AM »
Paul,
Hmm. So you are charging a 48V bank that way?Any way to calculate how many RPM's an alt needs to reach 57.6 volts? I seem to recall the LN-555 alt I have says max 7k rpm.
Jonathan
dbcollen
« Reply #10 on: December 28, 2014, 10:59:42 AM »
you don't even need to spin it really fast for 48v, you can get a few hundred volts out of most alternators if you need to. It is mostly controlled by the regulator in the alternator. You can build a regulator for any voltage.
madlabs
« Reply #11 on: December 28, 2014, 11:55:00 AM »
At what kind of current? The controller is no prob. Can you drive the field coil with more than 12V?
I'm guessing the efficiency of the alt goes down, I'm sure there is a reason the do make 48V alts. Still, might be a good compromise for me.
Jonathan
dbcollen
« Reply #12 on: December 28, 2014, 12:50:27 PM »
You could theoretically get rated amps out of the alt, in real life they only provide rated current for a few minutes before they heat up. micro hydro has been using delco 10si and 12si and large frame motorcraft alts for years in 12,24 and 48v for many years, They commonly use a rheostat to control the field. You could build a pwm field controller  for any volts you want, but remember those alts are lucky to be 50% efficient and take lots of power to drive. 50a @ 50v is 2500w and would take 7+ Hp to drive. The large frame motorcraft alts in the 70-100a range for a 70s full size ford or Lincoln are good choices and still fairly cheap and available and externally regulated. The claw rotor can take more than 12v, but the pwm duty cycle could easily be limited to 25% duty and the rotor would "see" 12v, and probably be more field than you need.
« Last Edit: December 28, 2014, 12:54:35 PM by dbcollen »
madlabs
« Reply #13 on: December 28, 2014, 03:55:11 PM »
I have a Leece-Neville 555 that I have run at max current (160 amps, 12V) for hours on end. It did have some decent extra cooling and I was running it pretty fast (forget RPM) which helps cool it too.
I also have a 250 amp /12V Leece alt that I have never used. Thing is a beast. I wish there was an easy lash up to see if I could charge my 48V bank with it. Might have to poke around about that.
Jonathan
« Reply #14 on: December 28, 2014, 05:06:18 PM »
all of the larger alternators i've torn apart are delta, at a minimum they can be rewired for wye which is a near doubling of voltage.
madlabs
« Reply #15 on: December 28, 2014, 06:13:20 PM »
Joe, I'll pull mine apart at the end of the week and see what I have. Good to know, thanks.
JOnathan
dbcollen
« Reply #16 on: December 28, 2014, 09:14:54 PM »
 you will not need to reconnect the stator, it will easily make 48v as is, try it and see.
PaulJ
« Reply #17 on: December 28, 2014, 10:23:53 PM »
"Paul,
Jonathan"
Yes, charging a 48V bank.
The 16 hp motor is overkill, but was the cheapest I could get with electric start to make it user-friendly for the rest of the family.
At idle with 12V on the alternator field coil it puts out ~10A into 50+ volts, 1500 - 1800 rpm (at a guess)  gives 30-40A, so 5000-6000 rpm or so at the alternator.
It's a longish and barely adequate wire run to the batteries so the alternator is running at 65-70V at these currents.
At 40A the alternator gets pretty hot and the efficiency must be dropping off so that's as far as I push it.
If you run the alternator side by side with the motor it will be running backwards, you'll need to reverse the fan somehow or it will fry.
I bent mine (carefully) with a couple of pairs of vise-grips so it worked backwards.
Paul.
madlabs
« Reply #18 on: December 29, 2014, 12:19:16 PM »
Paul,
Thanks for the information. Someone actually doing it is the best sort of comfort before trying it. I think I have a backwards fan for my smaller alt. I'd have to get one for my big alt. Both are cast aluminum so no bending. I have beaten an old GM alt to run backwards, worked fine.
Thanks!
Jonathan
« Reply #19 on: December 29, 2014, 02:46:49 PM »
A typical 12v alternator cuts in about 1000 rpm so it will make 48v at 4000. Drive it at about 5 to 6 000 and it will work fine on 48v.
I would use an external rectifier but in reality it is most likely the modern diode packs are good enough for 48v, some old ones may not be up to it.
I wouldn't push the field much beyond 15v it will saturate the claws anyway so you gain nothing. It will be much more efficient, for the same power out the current out will be 1/4 so the stator loss will be 1/16 of the 12v case.
Probably a nice big 24v model from a truck would be even better but a 12v one will do,
The fan will not need to do much at 48v so running the fan backwards would be possible if you have to do that.
madlabs
« Reply #20 on: December 29, 2014, 10:08:15 PM »
Flux,
So if I heard you, the alt won't get as hot because the amps will be lower. That sounds good. As describded above, I have a very large 12V alt I'd like to try. It has also been suggested to rewire it from wye to delta. What do you think of that.
I can replace the diodes pack with externals, no big deal. I can also limit the field coil to 15V. Are you saying the alt will be more efficient being driven at higher rpm and voltage? If so, is the sole reason they make 48V alts is to make the cut in speed lower?
Thanks for the help!!
Jonathan
phil b
« Reply #21 on: December 29, 2014, 10:35:14 PM »
One thing to keep on the back burner is you can buy a 120 or 240 split phase gasoline 3500 watt generator at the home renovation stores for $500 or less. Just in the case you get in a pinch...
Phil
« Reply #22 on: December 30, 2014, 05:04:34 AM »
On a vehicle the winding is chosen to supply normal required power at minimum engine speed. At high speeds the field voltage is reduced to a low value. If you are prepared to keep the speed up and keep a high field you can get a lot of power at 48v.
If it is delta connected you will reduce the speed needed considerably by wye connecting it. If it is wye connected now, don't try delta, the speed will be too high.
Early alternators were wye connected but with the modern output requirements the wire becomes too thick for convenience so many are now delta connected.
Going from delta to wye gives you a 170% increase in volts for the same speed so it virtually becomes a 24v alternator.
madlabs
« Reply #23 on: December 30, 2014, 01:16:26 PM »
Flux,
Good stuff. At work for a 72 hour shift but will dig into my alts when I get back. I'm sure I'll have more questions.
Thanks, looks like I can do this without selling a kidney for a 48v alt!
Jonathan
waitatian
  • Country: nz
« Reply #24 on: January 03, 2015, 04:20:55 AM »
I am using a 4WD 24v alternator directly connected to a 3.5 hp Honda motor for 48v. The field is driven from the output through a resistor. The output voltage/current is changed by varying the RPM of the motor. It can generate about 1kw.
madlabs
« Reply #25 on: January 04, 2015, 10:53:42 AM »
Wait, are you using a lovejoy or similar? Or is it belted? Should be able to squeeze a little more than a kW out of it.
Jonathan
  • Country: aq
  • Village idiot
« Reply #27 on: March 08, 2015, 03:35:50 AM »
Everything Flux has said I  agree with from my playing with these things.
I wrote this some time back.. it has 2 parts, and that unit runs 12 or 24v switchable with the regulator that has about 12 parts in it.... fully dial up whatever you want.
http://www.anotherpower.com/board/index.php/topic,492.0.html
http://www.anotherpower.com/board/index.php/topic,500.0.html
I do it a bit different now, but this will give you all you need to know to make it happen..... simple stuff indeed... I now incorporate the little diodes as well.... stops it drawing power into the regulator when stopped, and not turned down......I know... should have done that on the first one too....
...................oztules
« Last Edit: March 08, 2015, 03:39:58 AM by oztules »
frwainscott
« Reply #28 on: January 09, 2016, 10:37:10 PM »
Ive been using an early ford alt coupled to a 5hp brigs for years to produce over 50 volts on old batteries to rejuvenate them .sometimes works,sometimes does'nt. But the diodes they use are rated over 100v and the alternators will produce well over 120volts .I use a resistor for the field and vary motor rpm for voltage/amperage.
There are three sides to every story: Yours,Mine,& the cold hard truth!
Warpspeed
« Reply #29 on: December 26, 2016, 04:00:21 AM »
Any standard 12v alternator will work fine at 48v.
As rpm increases voltage increases.
In most vehicles the alternator is driven about x3 or x4 engine speed.  The cut in voltage where the alternator light goes out might usually be about 500 to 700 engine rpm.  That is often around 2,000 alternator rpm.
To reach 48 volts the alternator will need to be doing about 8,000 rpm, and a bit more than that to supply full rated current.
That sounds horribly fast, but if your vehicle engine is regularly taken up to 5,000 rpm, the alternator will be x3 to x4 that.  They are quite happy to run at 20,000 rpm continuously for year after year so 8,000 rpm is nothing.
You will obviously need to remove the inbuilt voltage regulator, and home brew something for 48v, but that should not be too difficult.
The diodes will be fine too, most are rated at 200v or more, and you will have zero diode problems with the original diodes at 48v.
Only real down side of vehicle alternators is that they are not very efficient.  They are made to be very small with not much copper and iron inside.  If your vehicle has a 200 Hp engine it does not really matter if the alternator takes 2Hp or 6Hp to charge the battery, so mechanical efficiency was never a strong design goal.
Small size, reliable, and cheap, yes.  Efficient no.
george65
« Reply #30 on: December 26, 2016, 10:56:27 AM »
withdrawn post
« Last Edit: December 26, 2016, 11:04:06 AM by george65 »
plasmahunt3r
« Reply #31 on: December 29, 2016, 07:45:14 PM »
I have a suggestion.  My understanding of alternator regulators, is that by default, the Field Coil is "ON".  When the desired voltage limit is reached, the Field Coil is switched off.  It switches off/on multiple times to maintain voltage.
So you can test the max voltage of an alternator, by bypassing the regulator, and hard wiring voltage to the field coil.  If the Field Coil is always on, then voltage is controlled by RPM only.
There are examples where people make their alternators into a welder.  They get up to 70 Volts from a standard alternator.  For Welders, they control current by adding a 5 Ohm Rheostat between Battery Positive and Field Positive.
« Last Edit: December 29, 2016, 08:04:13 PM by plasmahunt3r »
Warpspeed
« Reply #32 on: December 29, 2016, 08:26:36 PM »
That is all true,  the field coil is a winding designed to operate at something less than the regulator voltage maximum.
So what happens when you start up your alternator, the regulator connects the field winding effectively to continuous full battery voltage. As rpm increases the field winding continues with full maximum excitation at about full battery voltage until maximum regulator voltage is reached (at usually about 14.2v) where the regulator begins to reduce the alternator output, possibly right down to zero with a fully charged battery.
If your battery is not fully charged, running at for example 13v , the alternator field still receives the equivalent full excitation of roughly full battery voltage, until it reaches 14.2v where voltage regulation commences.
For 48 volt operation, you must ensure that the field winding never sees more than about roughly 14v or it is likely to overheat and possibly burn out.  So the voltage regulator system must be designed to only supply 14v maximum to the field winding until the 48v is reached, where normal voltage regulation begins.
It functions  exactly the same as for 12v, except the alternator rpm needs to be up at about four times the normal 12v speed to reach 48v.
If you had a bike as a kid, you will probably remember, the faster you peddle, the brighter the headlight.
Its exactly the same.  A 12v alternator can easily reach 48v if you spin it fast enough, but you must safely control the field winding voltage to a reasonable maximum to prevent it overheating and burning.
There are several quite different ways to do that. You could power the field winding from a 12v dc supply derived from the main 48v battery somehow.
Or you could connect a large wire wound resistor in series with the field coil so it drops  around 36v across the resistor.  The voltage regulator then puts the full battery voltage across the resistor plus field, but the field winding only gets 12v of that.
The last method is to design the voltage regulator itself so it switches on and off (most do that already) but instead of switching it on all the time to 100% duty cycle when full battery charging is required, you arrange it so its on only 25% and off 75% when full charging is required.  That effectively does the same thing when powered from 48v as having it on for 100% does at 12v. Its just the usual PWM.
So you usually get to either make or buy a special voltage regulator.
But the 12v alternator itself will work fine at 48v.
