Author Topic: 48V alternator (ICE driven)  (Read 37564 times)
plasmahunt3r
Re: 48V alternator (ICE driven)
« Reply #33 on: December 29, 2016, 10:57:24 PM »
You can run a pre-Regulator circuit to drop the 48V to a reasonable level for the field coil.  You can use either a NPN or N-ch MOSFET, but the MOSFET can generally handle more current.  I sketched up a quick circuit.
Don't forget the Heatsink.  You can get an Ohms reading on the field coil and figure out how much current it requires.  Then you can figure out watts for dropping 36v.
Warpspeed
« Reply #34 on: December 29, 2016, 11:11:24 PM »
Yup, that is certainly one way to do it.
Pretty sure field current will be in the three to four amp range for most alternators, but it does vary with size and brand.
At 36 volts that is around 100 to 150 watts dissipation.
Both the heat sink and transistor will both need to be very large.
If you decide to use a wire wound resistor instead, it  too will need to be in the same power range.
Best ones to use are the aluminium clad type, bolted onto a large flat heat sink.
Probably something about a foot square should do it.
http://www.ebay.com.au/itm/200W-Wirewound-resistor-Aluminium-Housed-Clad-5-0-1-30K-Ohm-various-1pc-/121767547079?var=&hash=item1c59e950c7:m:mcm5yC8-aiBekXOATnMXCEA
OperaHouse
« Reply #35 on: December 30, 2016, 02:59:18 AM »
But what happens when the wind stops?  You are still dumping current into the field.  I don't remember them being that good at self excitation.  Anyway, the field coil is just a big inductor and you could easily PWM it even with just a simple TL431 circuit, not wasting any heat.
Warpspeed
« Reply #36 on: December 30, 2016, 03:39:12 AM »
This application is being driven by an internal combustion engine, so that its not a problem.
It would not be too difficult to automatically switch off field excitation at zero rpm,  through design of the regulator.
PWM drive of the field winding is an excellent idea in any case.
I would be very surprised if anyone is planning to gear up a wind turbine or hydro to produce 8,000+ rpm.
This application is really only suitable for a gas or diesel engine, where there is no shortage of drive power, as the efficiency of  car alternators is so pitifully low.
george65
« Reply #37 on: December 30, 2016, 10:22:40 AM »
Pretty sure High RPM is NOT a factor. The power applied to the rotor controls the output more than speed. Once the alt is up to it's design speed range, it's the rotor current that controls the output not spinning the bejesus out the thing.
I also believe the Field Voltage does NOT have to be limited to 14V at all.  You can supply it any voltage you like to get the output Voltage you require as long as you watch the AMPS going into the windings which are what determines the heat load they see NOT the volts.
Also the efficiency of car alternators themselves is not low at all. They are designed exactly the same as any other High efficiency alternator. The claw pole design is used in every sort of commercial generation.
What makes car alts inefficient is not the design of the alt but the very crude but robust design of the control electronics.  There are controllers available that will let the alts run to 72V+ and are extremely efficient, right up there with that of commercial power plant generators.
There is a LOT of misinformation parroted about car alts, I suspect mainly by those that have never really used or experimented with them in the applications they speak of.
OperaHouse
« Reply #38 on: December 30, 2016, 12:24:36 PM »
There are adjustable buck converters that will work up to 60V to supply the lower field voltage.  It is also very easy to fool these buck converters, using only one extra wire to the board, that can adjust the field using a TL/LM431 like every line operated supply does.
plasmahunt3r
« Reply #39 on: December 30, 2016, 12:57:14 PM »
Forget about the Field coil.  If I were doing this, I would get a 48v Permanent Magnet Alternator.  They don't need a field coil and they are designed to run at low RPM.  Low RPM means less fuel to operate.  Plus no brushes to wear out.  Overall savings in the long run.
You can buy a Windzilla Permanent Magnet Generator for around $360.
You can make or buy a regulator to control voltage.  Since you are using an engine, and you can control RPM, your throttle can be you voltage regulator.
Warpspeed
« Reply #40 on: December 30, 2016, 02:53:25 PM »
George, why does  the alternator light come on in some vehicles if the idle speed is set too low ?
Its because the rpm is not high enough for the alternator to self excite. To reach 48 volts you do need higher rpm than to reach only 12 volts.
The field winding is an electromagnet. It is the ampere turns in the wire that generates the magnetic field.  Current is determined by Ohms law. As you increase the applied voltage, current also increases in proportion. Power is also dissipated in the winding as heat.  If you increase the applied voltage too far, two things will happen.  First the magnetic path will saturate, and second the temperature of the winding will increase.
by spinningmagnets
Efficiency is relative.
No, there are some huge differences in alternator design. Try comparing the electromechanical efficiency of a really good axial flux alternator to a car alternator for instance.
The control electronics cannot increase the output of an alternator, it can only only regulate (reduce) the output by weakening the field excitation.  Voltage regulators are not crude these days.
Early regulators used vibrating mechanical contacts, later ones an electronic circuit board. Today its all done in a single sealed hybrid chip.  Very robust and reliable.  But the alternator itself has not changed in basic electromechanical design over the last sixty years.
What do you do for a iiving George ?
I am a retired power electronics design engineer.
« Last Edit: December 30, 2016, 03:15:56 PM by Warpspeed »
Warpspeed
« Reply #41 on: December 30, 2016, 03:31:16 PM »
That is a much better option than a car alternator for all the reasons you mention.
Its a toss up between controlling the engine throttle, or placing a PWM buck regulator between the alternator and battery.  Either way, it requires a bit of ingenuity and know how to get it all working, but agree its a much better approach.
The main attraction of using car alternators is that they are usually free, and often the IC engine is free too.
So even if the final result is not spectacularly good, its still possible to create something very useful for minimal outlay and a bit of fun.
george65
« Reply #42 on: December 30, 2016, 08:33:19 PM »
I don't know what you did specifically but I can guarantee it was not working hands on with these type of machines.
My only knowledge is hands on not professional but there are people and products out there that directly contradict much of what you are saying.
It's not a matter of my opinion or qualifications, it's a matter of fact and proof that shows much of your position is patently incorrect. people are out there doing and there are products that allow them to which are known, readily available and do not follow your position of high speed and other statements.
Have you ever worked with Car alts in this way in a hands on, practical application?
From your statements I would say that is a pretty definite NO.  If I'm incorrect, could you show me what you have done that disproves my position?
Warpspeed
« Reply #43 on: December 30, 2016, 08:37:16 PM »
Yes sure I have.
O/k choose any one specific point that I have made, that you consider to be totally and absolutely dead wrong, and let's discuss that in depth.
  • Country: aq
  • Village idiot
« Reply #44 on: December 30, 2016, 10:59:54 PM »
George....
Take it from me. I have written articles on conversion of alternators on this and other sites... I think on  this site it was "playing with alternators" where the theory and practice with lots of pics is covered in depth... down to regulator design and 8 diode units, back MMF and current limiting, rotor design and construction etc etc.
Everything Warp has stated, is fact.... I'm sorry you will just have to live with it.
Until you understand the back MMF in particular for current limiting of the units, you will be seeing things you can attribute to things that are not really driving the result.... it is all inter-related.
I have no qualifications in this, but have put in the practice... and then did the theory to explain what I was seeing.
EDIT It was here for part 1.. not this site
http://www.anotherpower.com/board/index.php/topic,492.0.html
There is a pic of a very very big one too... about 3 tons
and part 2
http://www.anotherpower.com/board/index.php?topic=500.0
Can't say I am excited about perm magets in there... no control means high forcing voltages at high rpm.... I prefer to have total  control and a few losses ( not more than 50 watts at the most...).from the rotor .
..............oztules
« Last Edit: December 30, 2016, 11:14:26 PM by oztules »
Warpspeed
« Reply #45 on: December 31, 2016, 12:45:51 AM »
Excellent alternator writeup oZ.
There are many ways to skin a cat.
If you are the average Joe with an old alternator, and a small serviceable gasoline engine, the way you did it is definitely the most logical and best way to go about it.
But someone else might find an F&P washing machine alternator or some other more obscure permanent magnet wind alternator, even a large ex military stepper motor, or maybe a treadmill motor.  All of these are worthy contenders, but there is one slight problem with all of them.
There is no really simple means of adjusting the output voltage or current, except by  tweaking the drive rpm.
Or alternatively building some clever fairly high power PWM electronics to do that.
My only voyage into the mysteries of home brew gasoline driven standby power have been an only partly finished project. And that has certainly been a very interesting exercise.
I have a 12Hp single cylinder air cooled Wisconsin driving a 240v alternator. I think its 3.6Kva, but am not absolutely sure of that.
Rigged it up with a 12v car alternator, 12v battery and electric start. I hate pulling a string to start things, especially as I am almost  70, and becoming more and more lazy as I approach middle age, hehehe.
I planned to run it off natural gas, with a home made carburettor, already have all the bits to do that, and operate that carburettor from a radio control model positioning servo to keep it at 50Hz. The original centrifugal governor is an evil thing long ago consigned to the wheelie bin.
The whole thing has been sitting there at the back of my very untidy garage for several years as an unfinished project.
Maybe one day, I will complete it................
Too many projects, too little time.
  • Country: aq
  • Village idiot
« Reply #46 on: December 31, 2016, 01:41:45 AM »
I am right now pondering my next move. I have a 48v unit to do, and so have built the car alt version as above.....
But...... I just got hold of a dead 3kw 240v AVR style 240v generator.... dead alternator, but good motor ( burnt windings )
I think I might rewind it as a 48v stator instead of 240v, and use the original rotor with slip rings, and just whack together a regulator for it, and try that too.... or rewind it as 240v and use a transformer I have laying about for the 48v part.
Decisions decisions......
Warpspeed
« Reply #47 on: December 31, 2016, 02:11:07 AM »
Three Kw at 48v is around 60 amps.
If you are going to rewind it for 60 Amps, you will need your Superman suit, or if you are Popeye, lots of spinach.
Its not like a car alternator where there are three windings.
A 60 Amp rms single winding is pretty serious stuff.
Even at 240v, that is still 12 amp wire to rewind, but not too difficult.
I think I would just rewind it as original for 240v, then go the transformer rectifier route.
If later on you change your mind, it allows a few more options.
  • Country: aq
  • Village idiot
« Reply #48 on: December 31, 2016, 02:46:48 AM »
It is this one again
http://www.anotherpower.com/board/index.php/topic,781.0.html
It ran for many months for 24/7 while the drought was on driving water pumps day and night... after many months... the drought stopped. It was left in the paddock beside the dam for a year or 2, and failed not long after it was restarted seasons later... seems the wasps and ants and water had given it a good going over, and managed to short out the fine AVR winding. If you look at that link above you will see the winding info..... so 250 turns over 10 coils or 25 each... for 48v it would be near 40+ turns over 10 windings or only 4 turns each.
I'm thinking 5 in hand will do it@ 1.2mm or so wire. I figure the duty cycle will not be excessive at full power, and most of the time would be closer to 40-50 amps.
However the main windings are sound, and really only need to rewind the  50 turn windings of .7mm wire so am torn between the two.... but a 3kw transformer will weigh a heap too, where as the winding will be air cooled, so can be a bit on the skinny side and survive.
So 4 turns of 5 in hand will probably do just fine as the  cooling is very  powerful........big  fan@3000rpm.
............oztules
« Reply #49 on: December 31, 2016, 03:09:31 AM »
one of the problems with cheap single phase generators is the harmonics generated by the non ideal rotor. in my case, the rotor is only 90 electrical degrees wide; if i were to bolt on additional pole pieces and then rewire the rotor's two coils for anti-series, i would have a 4 pole machine.
anyhow: i think single phase generators are more efficient with concentric windings when the rotor is not sinusoidal. this should be the case particularly when the length to diameter ratio of the generator head is approximately 1:1.
much larger motors and generators  have higher length to diameter ratios (approaching 3 or 4:1 length to diameter for large 2 pole synchronous generators), they have sinusoidal flux distribution in the air gap and they are all wound approximately the same way,  lap winding: ~9.5:24 ratio. meaning: 42 separate coils span 17 slots out of 42 slots. other common slot numbers are 54, 60, 72, 84, etc.
so given that information i wound my generator with 24 coils each spanning 10 slots.
if you do want to rewire a generator that will rectify directly to dc at high amps, i might consider something as ridiculous as winding as many separate coils as there are slots, and rectifying each on individually.
if your generator has a rotor that can generate a much more sinusoidal waveform, then it should be more efficient to wind a multi phase machine.
in my case, the 145 volt coil groups are wired in wye to get 230vac. as such, 21 volts worth of third harmonic (rectifiers eat third harmonics for lunch) disappears.
so i might have a more efficient generator if i rectify each single phase 145vac coil group separately and pull power from it at 140 vac*141, rather than pulling power from it at 230vac*1.41.
a couple photos here http://www.fieldlines.com/index.php/topic,149061.0.html
« Last Edit: December 31, 2016, 03:14:17 AM by joestue »
Warpspeed
« Reply #50 on: December 31, 2016, 03:17:39 AM »
I am more used to designing and winding transformers.
Funnily enough, just finished winding a small one myself earlier today.
Its a dc to dc converter should provide  2.5Kw at 30Khz.
Five x 1.2mm sounds like about 30A for a solid standard garden variety bog ordinary 50Hz transformer in free air.
But with a fan and bulk air, and plenty of heat conduction to the outer cast iron frame, its probably conservative for your expectations.
Never attempted a rewind as complex as that one.
You are a much braver man than I  oZ.
Joestue, you posted just ahead of me.
That is an absolutely brilliant suggestion, multi phases  solve a whole lot of problems, and makes some very nice direct current.
Never thought of that, but you are quite right.
There are some pretty bright people here.
« Last Edit: December 31, 2016, 03:25:45 AM by Warpspeed »
« Reply #51 on: January 01, 2017, 07:35:15 PM »
I suppose I should confess I am now rather curious what kind of power a car alternator will suck up at 20,000 rpm with a full field exciton of 4 amps at 12 volts.
my guess is there will be about 1 hp of air drag and eddy current losses. but at 20,000 rpm the fan might be pulling as much air as a typical household vacuum cleaner, through the alternator. so God knows what the temps will be.  ;D
keep in mind the eddy currents set up in the iron oppose the field coil's amp turns. so the volts per hz will decrease as rpm rises..
Warpspeed
« Reply #52 on: January 01, 2017, 07:59:45 PM »
Yes indeed, but the output power will be pretty considerable as well.
Yes, and that is very important.  Its what sets the output current and keeps it constant as rpm rises.
If its a 65 amp alternator or an 85 amp alternator, whatever it is, the designer worked out the volts per hz and inductance of the windings to set a safe maximum current.  We are not changing any of that.  What we are doing is weakening the field at 48 volts not 12 volts to control the output voltage.
If it can deliver 65 amps at 14v (910 watts)  it should be able to deliver 65 amps at 56v (3,640 watts).
It will really be spinning pretty fast, but the dc output current is limited only by the copper wire gauge in the star output winding, so that does not change. The diodes too will be quite happy at four times the output power.
One further thought on all this.
The original field winding needs around 14v at probably about 4 amps to generate a strong enough magnetic field, just safely below magnetic saturation, for full maximum rated output.
All the previous suggestions above ^^^ assumed we keep this original field winding.
It should not be too difficult to rewind the rotor, as its just a plain simple bobbin winding.
So what would be needed would be to rewind the rotor with wire of half the original diameter (one quarter the cross sectional area) but with four times as many turns.
So instead of having X turns and four amps, we have 4X turns with one amp.
Same ampere turns, same volume of copper, and sixteen times the ohmic resistance.
But we can now operate our home made voltage regulator at 48 volts output instead of 12 volts output.
Much more efficient., especially as its now only one amp required
And as oZ has already shown us, the rotor halves come apart very easily for a possible rewind.
If you don't have a humongous hydraulic press, your local garage or servo is certain to have one.
A six pack of beer on a hot day should have it apart in seconds.
« Last Edit: January 01, 2017, 08:31:21 PM by Warpspeed »
plasmahunt3r
« Reply #53 on: January 02, 2017, 04:53:04 PM »
Since you have the rotor apart, I think 2 Microwave ring magnets will fit in there, replacing the coil.
Warpspeed
« Reply #54 on: January 02, 2017, 05:31:16 PM »
That would certainly work, and so would several rare earth magnets placed around in there, instead of the bobbin winding. Whatever you decide, once the steel has magnetically saturated, there is no further increase in alternator output.  So there is no way to lower the rpm requirement for higher required voltage, at least not without rewinding the star output winding.
The disadvantage of a PM rotor would be that the output voltage could not then be so easily controlled.
Something that will work really hard then pull the charging current right back to zero once full battery voltage is reached is an absolute necessity. Its pretty important not to boil the battery !
It could certainly be done with some kind of buck regulator on the output, but that would have to carry the full alternator output power, perhaps a couple of kilowatts.  Its much more convenient to control the much smaller current in the field winding, the power required to do that is only roughly about fifty watts, not kilowatts.
Controlling the IC engine  throttle opening is another possibility, but it is not a very nice way to do it.
And if something goes a little bit  wrong, once again you might cook a battery.
The original automotive voltage regulator worked fine at 12v, it just needs something very similar to work in the exact same way, but designed to work at 48v.
OperaHouse
« Reply #55 on: January 02, 2017, 05:43:24 PM »
Not without a non magnetic shaft.
Warpspeed
« Reply #56 on: January 02, 2017, 05:53:16 PM »
Yes, I see what you mean.
It could still be done, but the steel shaft is a definite problem to be overcome for PM operation.
A permanent magnet modification would still be a backward step IMHO.
  • Country: aq
  • Village idiot
« Reply #57 on: January 03, 2017, 02:31:40 AM »
In practice I think a n45 neo that big would possibly saturate the shaft it would behave as a non-magnetic shaft anyway......plenty of lines left for the job I suspect
But I agree with Warp, it would be a backward step, particularly seeing how simple a regulator for it is ( in those links to playing with alts). I use a 7 dollar 7amp buck off ebay to get the 12v for the regulator to drive the rotor... works perfectly stable.... and totally controllable with a pot so you can choose your charge rate if your motor is not powerful enough to drive full power out of it when the battery is flat... and your only running a 4 or 5 hp motor from the dump.
It is not wildly efficient..... but is eminently doable for free most times.
...........oztules
« Last Edit: January 03, 2017, 02:42:58 AM by oztules »
Warpspeed
« Reply #58 on: January 03, 2017, 03:06:06 AM »
Have to agree, anything rescued free from the tip at zero cost is definitely a bargain.
I suppose if you desperately wanted to try a PM alternator, a brass shaft might be  up to the job.
If I was doing this myself I would just rewind the field for 48v. Its probably  a 15 minute job.
« Last Edit: January 03, 2017, 03:14:01 AM by Warpspeed »
« Reply #59 on: January 08, 2017, 08:41:36 AM »
Alternatively, if you don't mind wasting up to 144 watts (at startup, though somewhat lower during run) you can put 9 ohms of (high-power!) resistance in series with the field coil.
You might try that for a quick conversion, to get it running and test it, then rewind it when you get around to it and/or are tired of wasting the fuel to make heat in the resistor, rather than delivering it to the load as power.
Another possibility (if the alternator is wye rather than delta) is to find a point on each winding that is 1/4 of the turns up from the wye point, carefully clean off the insulation, solder on a lead, and use these to feed the regulator's AC sampling inputs in place of the ends of the wye.  (You'll also need three more 5A diodes to provide a "virtual 12v circuit ground", rather than leaving the regulator's negative terminal connected to the now-48V winding's rectifier's negative terminal, and the "alternator light tickler circuit" will need a rework.)  Then the alternator operates about as designed and no extra power is wasted.
You could also do this with external 4:1 transformers, even if the alternator is a delta (the transformers can still be connected wye), though your regulation accuracy would suffer slightly.  Get some cheap Radio Shack transformers and rewind them as autotransformers.  You'll need at least enough core to handle 48 watts multiplied by the transformer's original rated frequency and divided by the alternator's frequency at cutin.  Automotive alternators run at a high frequency compared to grid mains (to reduce the amount of core and wire required) so that's a pretty small core.
« Last Edit: January 08, 2017, 09:31:04 AM by Ungrounded Lightning Rod »
plasmahunt3r
« Reply #60 on: January 09, 2017, 09:54:15 PM »
I was looking at DC-DC converters on Ebay, and I noticed encapsulated golf cart 48v to 12v converters, 10A & 30A.  For around $14 bucks, you can get the 48v to 12v 10A converter and run your field coil off this converter using your 48v battery bank.  Then RPM will get the voltage you require.  Simple.
« Last Edit: January 10, 2017, 02:21:46 PM by plasmahunt3r »
bergmanj
« Reply #61 on: January 16, 2017, 12:08:47 PM »
Folks: Just "thinking out loud".
What about a hybrid field consisting of a ring magnet capable of, say, 50% power output excitation (or 10%, or 100%, or anything desired); and an electromagnet that would buck / boost the actual working field strength to control actual output needs?
Yes, I recognize that this would not be "fail-safe" with regards to field control failure.  but, what control scheme IS totally "fail-safe"?
This kind of hybrid field would be self-exciting, and controllable.  It could also "save" the "waste" of output power at peak loads when needed most (if, say 100% power PM excited, then countered by electromagnet at max. equivalent opposite field when no external load is present).
I know that there are probably "cracks" in this thought!  But, want to hear other's thoughts anyway.  Makes for good conversation that may continue to move things forward.
Regards,   JLB
p. s. Not on here very often due to lowly dial-up internet connection at home; am at a high-speed connection right now.
« Reply #62 on: January 16, 2017, 03:48:51 PM »
one way to field weaken an automobile alternator would be to stack two of the stators as in figure 7 http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.569.5759&rep=rep1&type=pdf the same method is shown in figure 16.
a coil of wire in the stator is what regulates the flux density.
it seems to me you could cheaply build a centrifugal governor to adjust the phase between two sets of magnets. getting the cams (or non linear springs) correctly built to get constant volts with rpm would be a bit of a fun challenge.
OperaHouse
« Reply #63 on: January 16, 2017, 05:04:14 PM »
If you are willing to make a non ferrous shaft so the magnets can be installed there is no reason to add a field coil.  Electronics can be added to make it do anything you want.  I'm confounded by all these Rube Goldberg attempts to avoid electronics which in the end involve as much electronics as doing it right.
Warpspeed
« Reply #64 on: January 16, 2017, 05:13:01 PM »
Definitely agree with that ^^^^
A brass shaft should not be too difficult to make.
bergmanj
« Reply #65 on: January 22, 2017, 11:39:06 AM »
Folks,
I've sat on these thoughts hoping that my dissapointment would wane; after several days, it hasn't; so, here goes:
I really don't believe that trying to "think outside the box" is so-called "Rube Goldberg" thinking, in the negative sense in which it seems to have been used here.  These kinds of thoughts have made actual leaps in science and technology many times over millennia.
Even if someone here should communicate something which may be initially considered by some others as being "stupid, ignorant, foolish", etc.; those ideas can be very valuable in that they may precipitate other ideas which have more practical merit.  This kind of thing happens over and over again continuously.  So, I, personally, reject the idea that "Rube Goldberg" is something that shouldn't be here.  I encourage it!
Both Einstein and Tesla (and many others throughout recorded history) were "Rube Goldberg" thinkers, according to their "society" and peers, early in their careers; yet, they revolutionized our world.
Referring to other folks' ideas here as being "Rube Golberg" just puts them down and totally discourages  potential progressive happenings on this website.  I really hope this is not the direction being taken; as, I find this whole body of knowledge very enlightening; and, with good practicable thoughts, and practical information from many directions and areas of expertise.
To a few of you: Lighten-up on those with whom you don't agree; they actually have great value here too!
Regards,   JLB
p. s. Many folks do not understand the difference between the words "practicable" and "practical": Practicable is used to describe an unproven idea which seems like it may work; practical describes an idea which has been proven to work; i.e., "Her idea may seem practicable; but, has not yet been proven to be practical."
