Author Topic: Attaching Solar Panels to Roof  (Read 8894 times)
THDLink
  • /\ Fenner wind farm
« on: January 14, 2015, 09:10:38 PM »
How does one attach a solar panel to a roof without making it leak?
If anyone has some resources they could point me to that would be greatly appreciated; all I can find are consulting sites.
"We're going to need more batteries"
gww
Re: Attaching Solar Panels to Roof
« Reply #1 on: January 14, 2015, 09:33:09 PM »
Have you looked on You tube.  every time something on my car goes bad I go there first and watch the repair being done.  I actually pick up a good ideal once in a while.
gww
THDLink
« Reply #2 on: January 14, 2015, 10:40:50 PM »
Not sure why I didn't think of that. I get it now, fill the screw hole with silicone. Thanks gww
gww
« Reply #3 on: January 14, 2015, 11:05:36 PM »
I have seen them use flashing and when the cable guy puts up a satilite dish the use those little blocks of tar like stuff under the feet.
Good luck
gww
« Reply #4 on: January 15, 2015, 12:50:52 AM »
Roofing tar is better than silicone.
And those conical supports with a sheet of flashing that slips under the shingles are even better.
TomT
« Reply #5 on: January 15, 2015, 02:02:41 AM »
When I mounted my panels .
I used large diameter flat washers inside and outside. And I filled the hole with silicone.
MattM
« Reply #6 on: January 15, 2015, 07:17:08 AM »
Use a caulking product called Firestone S-20 "water block".  Gooey forever.  Use disposable towels to clean up wicks as it will stretch miles.  Firestone Water Block Seal (2-20) is designed to provide a seal when used in compression.
« Reply #7 on: January 15, 2015, 05:12:32 PM »
pitch pad under each roof penetration http://www.amazon.com/Ambient-Weather-EZ-46-3-Tripod-Installation/dp/B003EB3C4S they last 20+ years. I pulled a tripod off my roof that had been up there for 35 years and the pitch [ads were still sticking well to both the tripod leg brackets and the shingles. I had to cut them with a knife to remove the tripod.
THDLink
« Reply #8 on: January 16, 2015, 07:51:41 AM »
I'm looking to put a panel on a east-west roof (not south facing) any suggestions on a simple structure design? I've seen one so far on you tube looks like there is too much metal being used.. or not.. I'll post a link
Thanks everyone for comments.
THDLink
« Reply #9 on: January 16, 2015, 06:01:19 PM »
Well now I can't find it.. any DOS and don'ts ? It's just one panel. I know one dont.. don't fall of the roof.
« Reply #10 on: January 16, 2015, 06:29:07 PM »
Adult erector sets called unistrut http://www.menards.com/main/electrical/rough-electrical/strut-supports/strut-channel-12-gauge-pre-galvanized-10/p-1628628-c-12477.htm
They make several type of nuts that slide into the channel
THDLink
« Reply #11 on: January 17, 2015, 06:28:03 PM »
Yes! This is what I am looking for
« Reply #12 on: January 18, 2015, 03:42:51 AM »
I didn't buy the slide in nuts because the slot pattern lined up with my solar panel z-brackets... next set I will buy them. Will be much simpler to use!
THDLink
« Reply #13 on: January 18, 2015, 12:03:22 PM »
Nice setup Mary B. I might borrow that design there  ;D
« Reply #14 on: January 18, 2015, 06:12:06 PM »
It has survived 90mph winds and the typical 3-4 day long 45mph++ snowstorm winds I get. I believe in overkill design!
Jason Wilkinson
  • Country: bb
« Reply #15 on: January 18, 2015, 10:03:56 PM »
Is that corn behind the panels ?
« Reply #16 on: January 18, 2015, 11:16:22 PM »
Yep the year I took that was corn in that field, can be soybeans or wheat too. Organic and when it is wheat I buy a bunch to make my own flour.
THDLink
« Reply #17 on: January 22, 2015, 03:40:45 PM »
It works in testing !
22 Volts Closed circuit voltage
Drops to 13 volts when loaded with 1 battery & inverter with 50 watt fan
Yay!
Check out my youtube video
https://www.youtube.com/watch?v=Lm_c1v0K4XM
« Reply #18 on: January 22, 2015, 04:15:19 PM »
Good man!
I like a good test with the outcome that I was hoping for.
(I also get character from the ones involving release of magic smoke...)
thirteen
« Reply #19 on: January 22, 2015, 11:09:40 PM »
Did you use unistrut for all the panels? 13
MntMnROY 13
THDLink
« Reply #20 on: January 23, 2015, 03:03:29 PM »
Good man!
  ;D     I think I'll need more panels, this turbine is an expensive lawn ornament so far
THDLink
« Reply #21 on: January 23, 2015, 11:40:35 PM »
OK exaggeration.. it's not windy. But I'll need a junction box for more panels.. till later.
