Author Topic: Double lug diode?  (Read 3138 times)
THDLink
  • /\ Fenner wind farm
Double lug diode?
« on: January 18, 2015, 01:04:17 AM »
Hi all.. I'm blowing up the message board!
So im looking at diodes.. I found stud blocking diodes. Some rated for like 85 amps... is that enough to hold back the battery or am I looking for one rated for the amp rating for the draw of the turbine( to prevent spinning backwards). Also, I can't find one with two lugs one at cathode one at anode.. just a lug at anode and a post-type-end (which looks "difficult" to connect) at cathode..
"We're going to need more batteries"
Re: Double lug diode?
« Reply #1 on: January 18, 2015, 03:37:00 AM »
Crimp a ring terminal on, put diode through an isolated heatsink or use an insulator(including for the post), slip ring terminal over and then lock washer and nut.
THDLink
« Reply #2 on: January 18, 2015, 11:20:19 AM »
Sure that makes sense but what about the cathode?
THDLink
« Reply #3 on: January 18, 2015, 12:18:37 PM »
I meant anode. I guess a ring terminal and a screw and washer will do it. The diode must be rated for the source not the battery.
XeonPony
  • Sanity is over rated!
« Reply #4 on: January 18, 2015, 01:15:50 PM »
And must be heavily cooled if using it any where near its rating.
THDLink
« Reply #5 on: January 23, 2015, 11:45:19 PM »
Good note. Thanks. I'll be using a 30 amp diode for 5.5 amp max (each). You think 120g (many fins) aluminum is enough?
