Unsaid in the linked document is an explanation of 'Fast Charge' and when it is to be invoked...
'Occasionally (4 or 5 times a year) the battery may be recharged at 2.40 VPC with a current limited to the values listed in the Table 1. This charging should not be allowed to continue for more than 16 hours'
During commercial back-up service you might have grid/generator/source outage events occurring with short notice that might require deeply drawing down battery string charge, the 'Fast Charge' is to prepare for the next outage(s)...
When faced with the two scenarios, high-rate charging or over-discharging a battery string, both (theoretically) reduce the strings' projected lifetime, the lesser of those two evils is 'Fast Charge'.
It's meant for when it's in your better interests to cook the string a little to prepare them for the next deep-draw down.
Example - Service call responding to a trouble code from a remote installation with grid failed & propane back-up generator faulting out - you show up with a temporary generator and those expen$ive batteries are already low low SOC, your mission is to get batteries back to 97% ASAP since you're pretty sure the grid will remain flaky and the sites' automatic generator needs an overhaul; fast charge the batteries and come back the next day and swap out the automatic generator would maybe better ensure the least damage occurs...
