Author Topic: stater wiring  (Read 3703 times)
troymoore4
stater wiring
« on: November 16, 2015, 07:54:22 PM »
i am planning out a generator that has multiple stators and rotors.  i plan on using the same winding, wire guage, and coil placement for each one.  i was wanting to know how to wire them.  di i wire them separately or together somehow?  if together, then what is the best method of doing so?
Re: stater wiring
« Reply #1 on: November 19, 2015, 12:33:00 PM »
3 phase...single phase..?    Run all output wires to rectifers.... Or is it ac your after ?
Re: stater wiring
« Reply #2 on: November 19, 2015, 12:39:58 PM »
Or just build a single stator larger alt...less complex and more robust...with the same output your looking for....
Speedx
  • Country: lb
Re: stater wiring
« Reply #3 on: September 02, 2022, 05:58:24 AM »
I want to make an single phase alternator to run at low rpm, give 20amp.
I want to know the basic of wiring and winding. How to make 100w to... KW. A simple tutorial. Thanks
Re: stater wiring
« Reply #4 on: September 11, 2022, 07:44:20 PM »
Hi Speedx,
Welcome to Fieldlines.
For a comprehensive guide, you can't do better than Hugh Piggott's plans.
https://scoraigwind.co.uk/all-of-the-books-by-hugh-how-to-get-them/
