Author Topic: Solar Hot Water Bypass Valve, Temp activated  (Read 2908 times)
shaniac
« on: May 04, 2016, 07:20:50 PM »
Hello all, I am looking to add a heat dump to my domestic SHW system. I am looking for a non electric valve that has a thermostat in it... so that when the temp of the loop hits a certain level, the valve allows the heated glycol to run through a radiator so it can cool down without adding more to the solar storage tank. I keep coming up short when trying to Google this valve, does anyone know the name of the valve I seek? Thank you for your wisdom.
shaniac
Re: Solar Hot Water Bypass Valve, Temp activated
« Reply #1 on: May 04, 2016, 07:36:15 PM »
Never mind, I just found one. Sorry for wasting anyone's time. Thank you.
http://www.dudadiesel.com/choose_item.php?id=Divert050&gclid=CjwKEAjwu6a5BRC53sW0w9677RcSJABoFn4s-JlaSx7vt2Ron29cMA4sccjU2BIPL3wROUYPz4WdmRoCJKTw_wcB
Google: Thermostatic Diverting Valves - Passive Automation of Solar Water Heat Dumps
« Reply #2 on: May 05, 2016, 04:27:41 PM »
Rig your heat dump to feed a clothes dryer and do laundry on days you know it will trigger...
