Author Topic: Control for heating with solar off grid no batteries  (Read 18276 times)
ontfarmer
Re: Control for heating with solar off grid no batteries
« Reply #108 on: March 23, 2017, 04:51:10 AM »
I will check that and get back.  Thanks
OperaHouse
« Reply #109 on: March 23, 2017, 07:04:52 AM »
A FET can be damaged by a static charge to the gate. Puncture occurs when voltage on the
gate exceeds 20V. Even a minimal puncture can cause the device to fail a long time after
that has occurred.  It is a good idea to place a resistor from the gate to the source before
building the rest of the circuitry.  This will prevent damage from a floating gate either
in construction or an inadvertent disconnect. A failed FET almost always has a short from
the gate to the source. A floating gate can cause the FET to partially turn on causing
excessive heat and then failure.
So, it might be a good idea to have a pulldown resistor on each gate so if one FET is
removed or common is lost, the other one is still protected. A 1.5K resistor on each gate
would work.  That program is from another project I was working on and I changed the A/D
input and output pins.
ontfarmer
« Reply #110 on: March 29, 2017, 04:39:47 AM »
Very Happy day yesterday I got the uno working.  The day was perfect for testing, heavy
overcast to bright sunshine back and forth several times.  Just have one pin operating at the
 moment but will hook up the other one.
« Reply #111 on: March 29, 2017, 06:35:40 AM »
Well done!  Hurrah!
ontfarmer
« Reply #112 on: March 29, 2017, 07:43:16 AM »
Thank you. I hope to have a better understanding for the next ones.
OperaHouse
« Reply #113 on: March 29, 2017, 08:36:19 AM »
So, does it actually seem to hold the voltage at power point?  Are the FET running cool.  How big is the load?  Did you do anything to adjust it?
ontfarmer
« Reply #114 on: March 29, 2017, 09:15:31 AM »
Yes the voltage says at power point.  The load varied a lot through those conditions yesterday.  At the end of the day when I checked the load voltage was 18  the panels130.  Just have one fet operating off pin #3 it is hooked to a 750 watt  240 volt baseboard heater and the fet  is only warm.  Going to hook up another heater that is the same to operate off pin #11 with its own fet.  Have not done any adjusting yet,  could use some help with that.
I am going to take one of the panels out of series and put it back in parallel. That will drop
the voltage  by almost 40 volt. Will the code have to be changed ?
ontfarmer
« Reply #115 on: April 01, 2017, 09:14:48 AM »
 Installed a second opto-isolator and fet.   Got the second baseboard heater hooked up which
is controlled from pin #11 on the UNO.  Today is perfect for observing the performance heavy
cloud cover to bright sunshine changing frequently. Drive #1 , #2 vary from both on full power to partial  power on just drive #1.  Very happy to see this is working.  Want to let you guys that have been following this know.
« Reply #116 on: April 01, 2017, 11:03:52 AM »
Thanks for the update: it's good to know when things work, as well as when they don't!
OperaHouse
« Reply #117 on: April 01, 2017, 11:11:41 AM »
Good job, you'll be doing a youtube video next. I'll need to do a 4 heater version next. It is tax time and the desk is cleared off for that for a while. How many adjustment pots do you have in the system now?  If you hav an old analog dc meter, it can be used to make the adjustment. Just tune for higher voltage. Software update will come soon. Buy more fets.
ontfarmer
« Reply #118 on: April 02, 2017, 04:59:43 AM »
Will not be doing a youtube video.  It has been quite a trip for me getting this far.  I am starting to get a bit of  a idea of how and why this operates.  There are two adjustment pots
in the system now.  I have a old analog meter that can be used.  No rush on new software
just when it happens.  ( still in amazement watching the load on the drive  change on this one )  My plan was to have two systems,  six panels on each  one.  Should I be thinking different ?  Have more fets on the way.
ontfarmer
« Reply #119 on: May 08, 2017, 04:15:29 PM »
Just an update  to let you know that the unit is working.  The load is controlled so the solar panels maintains  power point voltage.  The fets only get slightly warm. A very slight change
of brightness to the panels and the load changes instantly.
OperaHouse
« Reply #120 on: May 09, 2017, 12:21:32 PM »
Sounds good. I'll be getting back into it shortly.Currently laying out a general purpose
board with a small capacitor bank and up to six FET. This will be be the base for a one
or two element MPPT heater, heater and MPT buck converter, linear current booster for
running a pump motor without a battery, and whatever I dream up in the future.  This will
make it easier for others to build these projects.  Then I will have to start cleaning up
and standardizing the code.
george65
« Reply #121 on: May 10, 2017, 11:25:22 PM »
If you could put up the code and the board schematic it would be a great help to a lot more people than just the code itself.
ontfarmer
« Reply #122 on: June 03, 2017, 06:25:16 AM »
Update changed the wiring on the panels to lower the voltage.  The open circuit voltage is now 135 volt. Will have to adjust the code.
OperaHouse
« Reply #123 on: June 03, 2017, 07:09:23 PM »
The software should adjust to that. There might be a problem if it drops somewhere below 60V as it may think the panels are not generating enough power yet.
The real problem I that you might have is that your loads are insufficient for the power you can generate.  Lower voltage complicates that even more.  Perhaps you are talking about adding some extra PWM outputs to the system.  I've just been waiting for when you want to take this further.  I'm en route to the camp now and will be getting deep into a new water heating project.  My father just died and I have some things to take care of first.
ontfarmer
« Reply #124 on: June 04, 2017, 03:01:41 PM »
Thanks for getting back and the information. My thoughts are with you on the passing of your father.
I figured it was the time of the year to return to the camp.
When I changed the wiring of the panels to lower the voltage I just added in a additional plug in. Now to change back just switch the wire to the other plug.
Got a question.  Was running the OCV at  170's wrong or harmful ? Since I changed it back to 135
OCV  do not get near the heat that I did.
Look forward to hearing what should be done
ontfarmer
« Reply #125 on: June 14, 2017, 03:35:30 PM »
Been thinking about OperaHouse he said he was en route to the camp.  Haven't seen him online or
any postings for quite a while ?
OperaHouse
« Reply #126 on: June 15, 2017, 10:10:12 AM »
I'm alive, the board has been quiet.  My radio water meter stopped working this winter. They only last a couple years because it only gets used 4 months a year.  Water usage provides a little charging.  They use lithium batteries and they don't like it below freezing. They wanted access and told them I'd be back in June. So, they turned off water at street and broke something. Yard is all torn up.  Once back couldn't just let them in as I had bundles of wire hanging by the meter. Had to rewire everything. If town ever figured out I am off grid the house would be condemned.  So been busy and have to come down from the hills to get internet access. I did manage to blow up an inverter doing something stupid. Think that was my last spare.  I have at least two to fix.
Microsoft did an update and my computer hasn't worked right since.  Anyone else having problems?  I have to pull out the battery each time just to get it to start up and don't like the the desktop.  Time to be doing a backup.
« Last Edit: June 15, 2017, 10:14:54 AM by OperaHouse »
« Reply #127 on: June 15, 2017, 01:26:15 PM »
OperHouse;
Depends on which version of Windoes you have . 10>> I stay away from, way too many horror stories from IT people. Windows 8.0 & 8.1 NOT even going to bother. There's two here at work and they know I barely care if they work. W7 , there are some updates that break it badly. IF you can get into the area of restore points you can even undo the updates, just pick a date when you know for sure it worked ok, then tell it to restore to that point.
You shouldn't lose any documents , I'm not lost any on ~ 25 desktops.
XP, there's a new update due to the randsomware attacks, but it seems to not bother any of the other stuff.
Hope this helps
OperaHouse
« Reply #128 on: June 17, 2017, 10:06:59 AM »
Win 7.   If someone told me this story, I would tell them they are nuts.  Computer starts up fine if I use only battery power.  If the wall wart is plugged in the screen just stays black, the power on LED does come on.  Remove wall wart and battery, reinsert battery and it will power up.  Then you can plug in the wall wart.
« Reply #129 on: June 22, 2017, 01:56:03 PM »
Operahouse;
Sorry for the late reply. 30th wedding anniversary time :-).
This certainly points to a Micro$oft update of sorts.
Since you can get it running, you might go into control panel, select the updates ( make sure and turn on "show installed updates"). Turn off automatic updates if it's turned on. Then delete  them until you're back a full 30 days , but do not allow it to reboot until you've deleted the last few ~ 3 possibly more. Be sure to remove any KB that has the last four numbers of 3977!! these deal with the motherboards and Micro$oft pushing it's secure boot. The UEFI is causing real issue for IT managers that use PXI boot managers to restore troubled computers.
