Author Topic: Test for Power Point of Panel with UNO  (Read 3004 times)
OperaHouse
« on: October 17, 2016, 11:55:33 AM »
One of the nice things about a microprocessor is you can build little tests into them.  In my house program I have a number of screens I can enter with a keyboard command to display charging, fridge, heating, resets, etc. operations and display variable values.  I've had some bad experiences with solar panels and this routine is a convenient way to check them.  The water heater elements serve as the dump load.  I just wait for a quiet time in the system when batteries are nearly charged and the fridge isn't running to do the test.  It is a straight forward process where I turn everything off that is used by the 36V string.  Then I record that open circuit voltage and start ramping up the PWM numbers till it reaches the end or the lowest test voltage I want, in my system that is about 47V.  The resistance is known so the maximum amperage is calculated based on the voltage.  That current is multiplied by the duty cycle percentage to get average current.  The average current is then multiplied by the voltage at that time to get power.   The power is compared with the previous power.  If higher, it is stored along with the variables at that time giving the power point of the panel.  All integer math.  Not super accurate, but repeatable.  It tells you basically what you want to know.  A large capacitor must be used on the panel power so the current averages.  Could be a useful addition to your program with some minor changes.   Half the value (aprox) of the divisor is added before any division to round up numbers.  At the end, keyboard stores the last key pressed.  Most screens keep displaying new data and are part of the program delay.  Dis a screen that only has a delay so the power point data stays till another key is pressed.
//                      H, HIGH POWER POINT SCREEN HEATERS #1 2000W & #2 1500W
  if (kbd == 'H' || kbd == 'h')                     // if H or h, send out POWER POINT
    analogWrite (11, 0);                             // Turn off 36V charging
    analogWrite (3, 0);                              // Turn off heater #1
    analogWrite (10, 0);                             // Turn off heater #2
    pmax = 0;                                          // reset pmax value
    Serial.println(" ");
    Serial.println("               HIGH POWER POINT SCREEN HEATER #1 & #2 ");
    delay (200);                                          // delay before reading voltage
    AI1 = analogRead(1);                             // read OPEN 36V PANEL VOLTAGE
    Serial.print((float) AI1 * 8 / 100);             // calculate voltage
    Serial.println(" initial voltage    ");
    // after initial voltage reading test each PWM value starting with
    for (int i=5; i <= 255; i++)                     // TEST EACH PWM LEVEL starting at 5
    analogWrite (3, i);                              // Turn on heater #1 7.81 ohms 2000W @ 125V
    analogWrite (10, i);                             // Turn on heater #2 10.4 ohms 1500W @ 125V
                                                            // Turn on BOTH heaters 4.13 ohms
    delay (500);                                       // delay before reading voltage
    long VOLTS = 0;                                  // reset VOLTS and declare as long first time
    //AI1 = 1023;                                      // TEST ONLY at max value
    VOLTS = AI1 * 4;                                 // add first value
    VOLTS = VOLTS + AI1 * 4;                    // add second value
    Serial.print((float) VOLTS / 100);            // voltage value at PWM value
    Serial.print(" voltage @ ");
    Serial.print(i);                                 // PWM value
    Serial.print("    ");
                                                     // calculate max possible Amps
                                                     // multiply by 10 so resistance is integer number
    //long Amax =  (VOLTS * 100 + 550) / 1040;  // max possible w/ HEATER #2 10.4 ohms (SMALL)
    //long Amax =  (VOLTS * 100 + 400) / 781;   // max possible w/ HEATER #1 7.81 ohms (MEDIUM)
    long Amax =  (VOLTS * 100 + 220) / 413;     // max possible BOTH HEATERS 4.13 ohms (LARGEST)
        // add 220 for round up, about half of divisor
    Serial.print((float) (Amax + 50) / 100);
    Serial.print("A max   ");
    long AMPS = (Amax * i + 150) / 255;        // actual amps from % PWM
    Serial.print((float) (AMPS + 55) / 100);     // add 55 for round up
    Serial.print("A   ");
    VOLTS = (VOLTS + 6)/ 10;                     // add 6 for round up
    long POWER = AMPS * VOLTS;
    Serial.print((POWER + 550) / 1000);       // add 550 for round up
    Serial.println(" power  ");
    POWER = POWER / 100;                 // divide down to whole watts
    if (pmax < POWER)                       // record maximum power points if bigger
      PWX = i;                                   // record maximum PWM
      pmax = POWER;                         // record maximum voltage
      VPP = VOLTS;                            // record maximum voltage
                                                     // look at raw A/D panel and
    if (AI1 < 590) i = 255;                  // end if under voltage condition
    }                                                // end for loop
    //       display power point conditions & return to normal operations
    Serial.println("                     end of test ");
    Serial.print((pmax + 6) / 10);           // maximum value of power
    Serial.print(" max power @ ");
    Serial.print(PWX);
    Serial.print(" PWM    ");
    Serial.print((float)VPP / 10);
    Serial.println("V");
    analogWrite (3, 0);                       // Turn off all heater #1
    delay (100);
    keyboard = 'D';                             // go to DELAY to maintain screen timing
                                                     // next and return to normal program
  }                                                  // end of this screen
« Last Edit: October 17, 2016, 12:08:17 PM by OperaHouse »
ontfarmer
Re: Test for Power Point of Panel with UNO
« Reply #1 on: October 18, 2016, 06:37:36 AM »
  OperaHouse your knowledge is endless.  I read through this post a few times.  The
sketch is not for beginners,  but some of it is similar to the one you done for me.
How has the weather been at the camp ?   Will you soon be heading back ?
OperaHouse
« Reply #2 on: October 18, 2016, 01:46:23 PM »
I't's 81 right now.  Last weekend I was ready to leave with it being 51 in the house. I will likely be leaving Friday.  Empty the water heaters Thursday, that takes a while.  Keep saying I'll get an air tank to blow the system out.  Code is just the same stuff over and over.  With all the additions to it over the years it is still only 21K of 32K of code.  That was just a little demonstrator of the FOR function and use of the keyboard command to select different routines.  But, I want to stress the need for periodic testing  of panels.  Stuff happens to things exposed to the elements, bad connections etc.  And those 25 year warranties are just a pipe dream.
